Orbi WiFi 7 RBE973
Reply
Orbi RBR50 - Armor BitDefender installation on Mac
quidneck
Hi  I have an Orbi mesh router and am trying to install Netgear armor Bitdefender on my Mac. After the application successfully installs on the Mac I am requested to log in using my Netgear user id/password.
When I enter the user id and password, I get the following message: “No internet connection found. Check your connection and try again”
Does anyone know what might be causing this and how I can fix this problem?
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 4
Accepted Solutions
DexterJB
NETGEAR Moderator
Re: Orbi RBR50 - Armor BitDefender installation on Mac
Hi @quidneck, welcome to the community! Are you able to login using the same credentials on armor.netgear.com? Did you use the link provided via the Armor app/UI?
Dexter
Message 2 of 4
All Replies
DexterJB
NETGEAR Moderator
Dexter
Message 2 of 4
quidneck
Hi Dexter,
Thankyou. It worked when I used the link on armor.netware.com. It didn't work when I initiated the install using the Orbi app on an IPhone.
Message 3 of 4
DexterJB
NETGEAR Moderator
Hi @quidneck, thanks for the update and confirmation! Glad to know that did the trick!
Dexter
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 3810 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
