Paulhr
Oct 26, 2021Tutor
Orbi RBR850 - Netgear Armour VPN not connecting on iOS devices
Purchased a new Orbi RBR850
Installed Netgear Armor/Bitdefender on iPad (Latest iOS 15)
Asked to install VPN profile
Web Protection VPN installed profile - server = dns.bitdefender.net/dns-query
VPN tries connection multiple times then times out - please aknowledge this as my issue.
I have trial subscription (7 days left) and would like to install this properly
as a side note - installed Netgear "My Time" and the VPN profile worked perfectly.
2nd question - will Armor VPN and My Time VPN clash?
If so, fix this issue as Netgear are promoting 2 features of which you can only use 1 at a time.
I want to use my time whilst protected with Bit Defender.
- Bear1969Aspirant
To make things even worse, this exact same problem also occurs when trying to use Bitdefender Total Security along with Bitdefender VPN on Apple devices…
- PaulhrTutorSo I’m not going mad then. As an FYI, no one @ Netgear seem to be interested in this dilemma they’ve created. Luckily this isn’t an enterprise solution. Customers would just throw the solution out on the front lawn. Unlucky for us we’re stuck with this.
