- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RAX 120 Netgear Armor activation error
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello,
i have purchased a Netgear Armor license and i try to activate it on my RAX120 Router. The Nighthawk app reports that Security is Not Activated.
When i click the button it asks me to Activate Trial. I proceed with the action but after 2-3 seconds i get a message that says Failed to Subscribe.
Searhing this forum i found that one way to fix this is to reset the Router. I did that but the Router stil refuses to work with the Netgear Armor. I also tried to Enable/Disable Remote Access without success.
Thank you
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RAX 120 Netgear Armor activation error
did you get an activate code?
if so, try this route
- Mark as New
- Bookmark
- Subscribe
- Permalink
i have activated the account in armor.netgear.com but the Router reports not activated.
- Mark as New
- Bookmark
- Subscribe
- Permalink
try this:
https://kb.netgear.com/000061809/I-get-an-error-when-I-try-to-activate-NETGEAR-Armor-what-do-I-do
Sometimes the enabling/disabling remote management can help.
Might be worth contacting support for the issue.
https://www.netgear.com/support/product/netgear-armor.aspx
also, maybe @Christian_R can help.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello KDIHALAS,
You may also try power cycling your router. If your issue persists, please send me a private message with your email address and router serial number.
Christian
- Mark as New
- Bookmark
- Subscribe
- Permalink
None of the actions in this thread solved the issue i have send a PM as requested.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I contacted bitdefender and they say my license is not compatible with the Router. They will change it internally. This is very strange since i subscribed to the service through the armor.netgear.com and i selected the Nighthawk device.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hopefully they're able to get it working properly for you!
