Orbi WiFi 7 RBE973
Reply
RAX20 Unable to activate Armor after factory reset
CCENT
Follower
Model: AX1800 WiFi Router (RAX20) : https://www.netgear.com/ca-en/home/wifi/routers/rax20/
Armor was activated previously, and there are 144 days remaining on the subscription checking https://armor.netgear.com.  After a factory reset and resetup of the unit, armor failed to activate. The button to start a trial can be tapped using the Nighthawk app but it will fail after loading for some time stating that it is unable to acquire a subscription.
Message 1 of 3
Guru
Re: RAX20 Unable to activate Armor after factory reset
Message 2 of 3
Guru
To get a hold of support for subscriptions services like Armor/Circle, click on "MyNetgear" at the top.
Register an account (or login) and then the device.
From there you can start the support process.
Click on: My Support---->Contact Support---->Get help with my subscription service
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1198 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
