Reply
RAX80 Armor?
bhouin
Follower
RAX80 Armor?
Is the RAX80 going to be Armor capable?
Model: RAX80|Nighthawk AX8 8-Stream WiFi Router
Message 1 of 4
DexterJB
NETGEAR Moderator
Re: RAX80 Armor?
Hi @bhouin, welcome to the community! As it stands, the RAX80 does not support the Armor feature and support does not have visibility of future feature updates. You can post on the Idea Exchange board instead linked below.
https://community.netgear.com/t5/Idea-Exchange-For-Home/idb-p/idea-exchange-for-home
Dexter
Message 2 of 4
Yanks1127
Ax12 armor
I need the armor added to my ax12
Is there any product or chance I can order this?
What similar routers are available that do use it.
Or products I can se against all machines getting a move and other commands direct from processor to pixe boot appx pass and change the entire system
Lenovo AMD Intel have swapped all boards and processors twice already
Model: RAX120|Nighthawk AX12 12-Stream WiFi Router
Message 3 of 4
DexterJB
NETGEAR Moderator
Re: Ax12 armor
Hi @Yanks1127, you may check the link below for the router models that support Armor.
https://www.netgear.com/landings/armor/
Dexter
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 2027 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
