- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Replacement power supply, who sells them?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am looking for a replacement Power supply for a ReadyNAS RNDP2000.
I believe I am being told that there is an internal power unit inside where the cord plugs into the unit. There is also a transformer unit that is external to the unit. Anybody know which one needs to be replaced?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Replacement power supply, who sells them?
Hi @MarkBdr
Welcome to the Community!
The parts you might be looking for will not be available online for reference since those are internal parts. It might be better if you can bring it to an electronic store for it to be checked.
Unfortunately, NETGEAR does carry these parts not sure if those are available online. But if it's the brick you need, it is widely available.
I would advise getting a new NAS instead it might be worth it than replacing the parts.
Regards
