wchp
Apr 22, 2019Luminary
Stateful or Deep packet inspection or other?
Does the Bitdefender/Netgear Armor firewall use SPI (Stateful packet inspection, e.g. SonicWall) or DPI (Deep packet inspection, e.g. Bitdefender Box 2) or is it just a blacklist of know bad sites and IP's and filenames?
- wchpLuminary
It uses DPI (deep packet inspection)
Ihttps://www.techrepublic.com/article/why-deep-packet-inspection-still-matters/
- Orbi-RocLuminary
Thank you wchp for the prompt response. How were you able to ascertain that if I may ask?
You know, I disabled Armor because I wasn't happy with Bitdefender mediocre (at best) support; and had too many issues on both Windows PC's and Mac's. But I also had issues with Ultra HD streaming on Netflix -- the video would skip here and there throughout a viewing session. But none of these issues, albeit annoying, were/are deal-breakers IF the filtering at the router level is adequate. So this puts my pursuit of this issue somewhat in context.
Again, thanks for your help. I believe that your posts have been very helpful, not only for folks like me who are still on the sideline, but for the Community at large.
