Orbi WiFi 7 RBE973
Reply
Trying Armor trial, will it work with my current norton
GatorMitch
I'm using Armor trial but have not installed Bitdefender on my clients which include pc's, android streaming boxes, iPhones, iPads. I have a norton anti-virus on all my pc's. I understand the Armor works on the router level, but was wondering if the Bitdefender would conflict with the Norton running on my pc's. I have subscription to norton that is good for another 8 months so I don't want to subscribe to Armor if I can't use Bitdefender with my norton antivirus. Can anyone tell me how this would work?
Model: RBK53|Orbi AC3000 Tri-band WiFi System
Message 1 of 4
Christian_R
NETGEAR Employee Retired
Re: Trying Armor trial, will it work with my current norton
Hello GatorMitch,
You should not experience any issues with Norton and NETGEAR Armor running simultaneously.
Christian
Message 2 of 4
GatorMitch
Thanks. How about if I add bitdefender on the same devices running norton.  My PCs currently use norton anti virus. Will I have problems if I install bitdefender on the same PCs currently running norton?
Message 3 of 4
Christian_R
Hi GatorMitch,
That should not be an issue. I would also recommend checking in with Norton to see if they have any additional info.
Christian
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 2180 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
