Orbi WiFi 7 RBE973
Reply
Using iPad Air 2 and Bitdefender armor will not work correctly.
Briansf
Apprentice
Just upgraded my iPad Air 2 to the latest software but Bitdefender Armor says I need to update to IOS 16. I cannot upgrade to the latest software because iPad Air 2 only accepts the earlier version. Anyway out other than spending 500 bucks for a new iPad?
Message 1 of 4
Accepted Solutions
Briansf
Apprentice
Re: Using iPad Air 2 and Bitdefender armor will not work correctly.
That's what I figured. Thanks for the response. I'll be upgrading.
Message 3 of 4
All Replies
Guru
Since the pad max iOS level is v15 and doesn't support 16, I would either upgrade he pad or if Armor doesn't work on the pad 2, might consider un-subscribing from Armor on this device.
Message 2 of 4
Briansf
Apprentice
Message 3 of 4
Briansf
Apprentice
For some reason I ran Bitdefender on my iPad Air2 last night and it worked just fine! Sorry for the inconvenience!
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 2392 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi 770 Series
