Orbi WiFi 7 RBE973
Reply
Whitelist website on Nighthawk MK63 router
jonnyaces
Hello,
We are using the netgear nighthawk MK63 router. In the last few days, we have been unable to access a particular website that we have been using through this route for over a year.
We are no longer using netgear armor.
We have been able to determine that we can access the website when we are not using the WiFi, we have also been able to determine that we are able to access this website when using a different router in WiFi.
Do we need to whitelist this site on the router and if so how can I do that?
Or is there something else?
Thanks,
Jon
Message 1 of 5
Guru
Re: Whitelist website on Nighthawk MK63 router
Did you disable Armor thru the Nighthawk app? If so, after it was disabled did you power OFF the ISP modem and MR router for 1 minute then back ON?
if this failed, you'll need to factory reset the MR and setup from scratch using a wired PC and web browser. Turn OFF any MS while you do this. Be sure to set up the SSID name and PW as same. Don't enable Armor or any Access Controls. Then check this web page for access.
Message 2 of 5
jonnyaces
Thanks for the response, I did not disable Armor, it is just expired.  But I will try the below and disable it to see if that helps and I will follow up with the information requested below
It is strange that as of now, it is only 1 website that we are seeing issues for and that did not begin until a few days ago
Message 3 of 5
Guru
Ok. Give that a try.
Ya seems odd. Hopefully this will get that site going...
Message 4 of 5
jonnyaces
ok that did not seem to work, I factory reset the router as instructed and it still seems as if this site will not work.
firmware version: 1.1.7.132_2.0.64
the Fiber DSL modem is Nokia provided by Altafiber(Cincinnati Bell)
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1615 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
