Orbi WiFi 7 RBE973
Reply
how to install Netgear Armor parental control
bcman79
Follower
I just purchased Netgear Armor then I downloaded the local protection on my Windows 10 pro desktop. Where are the parental controls? I thought that this subcription came with parental control? Do I have to download another stand alone application for this? I'm confused, please help. Thankyou
Model: R7000|AC1900 Smart WIFI Router
Message 1 of 2
Accepted Solutions
DexterJB
NETGEAR Moderator
Re: how to install Netgear Armor parental control
Hi @bcman79, welcome to the community! Armor is a security feature meant to protect your devices from cyber threats. As for Parental Controls, you may want to look into the Circle feature which can work alongside Armor. The links below may help out.
http://www.netgear.com/landings/circle/
What is Circle and why should I use it with my NETGEAR router?
https://kb.netgear.com/000038873/
Circle service plans and features
https://kb.netgear.com/000038872/
How to enable Circle on the router UI
https://kb.netgear.com/000038871/
How to enable Circle using Circle App
https://kb.netgear.com/000038870/
Please let us know if you have questions.
Dexter
Message 2 of 2
All Replies
DexterJB
NETGEAR Moderator
Dexter
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 3724 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
