Orbi WiFi 7 RBE973
Reply
netgear armour
BrianJ44
Guide
netgear armour
i deleted one of my rbs 50 satelites from my netgear armor. Is there a way to get it back so it is showing as a device and being protected?
Message 1 of 6
Accepted Solutions
Orbi-Roc
Luminary
Re: netgear armour
I am not sure, but I think that turning if of and back on again would cause it to be picked up again; and if that doesn't work, perhaps rebooting your Orbi would work. Good luck!
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 2 of 6
All Replies
Orbi-Roc
Luminary
Re: netgear armour
Message 2 of 6
DexterJB
NETGEAR Moderator
Re: netgear armour
Hi @BrianJ44, welcome to the community! As suggested by Orbi-Roc, you can reboot the satellite and check if it appears as a newly connected device then move it to My Devices.
Dexter
Message 3 of 6
BrianJ44
Guide
Re: netgear armour
Thank you Orbi-Roc, you were right...I resynced it and it was picked up again.  Thank You!
Message 4 of 6
BrianJ44
Guide
Re: netgear armour
Thank you DexterJB, all set!!
Message 5 of 6
DexterJB
NETGEAR Moderator
Re: netgear armour
Hi @BrianJ44, good to know that did it! 😄
Message 6 of 6
Discussion stats
  • 5 replies
  • 3802 views
  • 4 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
