Orbi WiFi 7 RBE973
Reply
pairing
hotsaxmark6
pairing
hi there, i am trying to couple PL1000 with PL1000v2, is this possible?
Model: PL1000|PowerLINE 1000 adapter
Message 1 of 6
Guru
Re: pairing
yes you can.
They both run off HomePlug AV and HomePlug Green PHY.
Notice how the user manual for V1 and V2 are the same? Just follow the sync instructions in the manual for adding extenders.
https://www.netgear.com/support/product/PL1000v2
Message 2 of 6
hotsaxmark6
Re: pairing
Why is this not working for me then, the PL1000 is a Wi-fi version? I can get the two separate systems to work with each other but I cannot get them to combine
I brought a pl100v2 kit & a pl1000 Wi-fi kit and I want to run them off one master but it’s not happening?
Message 3 of 6
Guru
Re: pairing
Did you look at page 19-21 of the manual about how to add extra adapters and to configure the security key?
Message 4 of 6
hotsaxmark6
Re: pairing
Hi Piemans, I believe I have, can you confirm the manual you are referring to please
I’ve attempted to factory reset the units but to no avail
Regards
Richard
Message 5 of 6
Guru
Re: pairing
The manual that I'm referring to is in the support link i posted.
it also has troubleshooting.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 1939 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
