Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
BR200 assign an IP address to the WAN interface
- Mark as New
- Bookmark
- Subscribe
- Permalink
2022-04-05
08:01 AM
2022-04-05
08:01 AM
Hello,
I use a BR200 router.
I can't find a way to assign an IP address to the WAN interface.
I don't have internet access.
I connect a PC to the WAN interface. On one of the LAN ports I put another PC. I manage to send a PING from the LAN to the PC which is connected to the WAN interface. But I can't send a PING from the PC which is linked to the WAN connector to the PC connected to the LAN connector.
Does this router allow you to have this type of link?
thank you in advance for your help
Cordially,
XSO
Message 1 of 2
- Mark as New
- Bookmark
- Subscribe
- Permalink
2022-04-11
10:04 AM
2022-04-11
10:04 AM
Re: BR200 assign an IP address to the WAN interface
Here again, WAN port IP can be done by DHCP or by assigning a fixed IP config. However, this is not what you are behind. LAN-WAN and WAN-LAN is always subject of many2one NAT, by default any connections from the WAN port is NATed, you might to use port forwarding for example. Full 1:1 routing is not available.
Message 2 of 2
