Orbi WiFi 7 RBE973
Reply
Block Local Network visibility
Howkoss
Tutor
How to Block Local Network visibility but allow Internet (Netgear Insight using WAC505 AC's)
Model: WAC505 Insight Managed Access Point
Message 1 of 2
DaneA
NETGEAR Employee Retired
Re: Block Local Network visibility
@Howkoss,
You may enable Client Isolation for a WiFi network so that the clients that are associated with the same or different WiFi networks cannot communicate with each other but still have internet access.  As reference, kindly read pages 51-52 of the WAC505 user manual here about Enable or Disable Client Isolation for a WiFi network.
It seems there is no option for Client Isolation in NETGEAR Insight. I suggest you to access the web-GUI of the WAC505 then enable Client Isolation then reconnect the WAC505 to Insight.
DaneA
NETGEAR Community Team
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1184 views
  • 0 kudos
  • 2 in conversation
Announcements
