Orbi WiFi 7 RBE973
Reply
Insight widgets Usage clients and usage traffic show incomplete graphics
KGA20
Hi community,
I want to report a bug that affects widgets titled "Usage:Clients" and "Usage:Traffic".
Graphics are not complete. As you can see on the following screenshot, the graphics are cutted on the top.
Same error if you apply a filter.
Cause is that left bar does not show the maximum value
Message 1 of 7
schumaku
Guru
Re: Insight widgets Usage clients and usage traffic show incomplete graphics
Strange, looks fine here:
Message 2 of 7
KGA20
Thanks @schumaku for your reply.
My versions are:
Web Portal Version : 6.3.26.7
Cloud Version : 6.3.26.8
do you have the same?
Message 3 of 7
schumaku
Guru
Difficult to have something different - it's a production system:
NETGEAR Insight Pro
Of course there can be certain flaws... @YeZ any ieas what can go wrong there?
Message 4 of 7
KGA20
I do not know if can help: All my devices are WAC505 y WAC510 and i am using last Google Chrome Versión 94.0.4606.81 (Build oficial) (64 bits)
Message 5 of 7
schumaku
Guru
Works similar on all current Chrome, Chrome Beta, Firefox, Edge here.
Those graphs "hanging down" from the top line visible on your screenshot look suspicious, too.
Message 6 of 7
KGA20
Since yesterday now graphics are showed correctly.
Thanks
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 1947 views
  • 0 kudos
  • 2 in conversation
Announcements
