Reply
Nighthawk RAX80 and Nighthawk EX7300. Comparability? Tech support no help.
6023HB
Follower
Can I use a two-year-old Nighthawk EX730 range extender with a new Nighthawk RAX80 router.
If yes, how do I set it up?
Thanks in advance.
6023HB
Message 1 of 2
schumaku
Guru
Re: Nighthawk RAX80 and Nighthawk EX7300. Comparability? Tech support no help.
Leaving the potential performance and/or compatibility issues aside, I would suggest to configure the extender as a wireless access point (requiring a wired network connection from the router to the location where the extender is to be installed).
No personal experience however. The very same you configure the extender to any random wireless router isn't it? As documented...
Message 2 of 2
Discussion stats
  • 1 reply
  • 1364 views
  • 0 kudos
  • 2 in conversation
Announcements
