Orbi WiFi 7 RBE973
Reply
Tunnelblick was not able to load a system extension
zeerocool
I am tryign to connect a mac to vpn on a BR500. The netgear application fails to launch does not morch with osx mojave. The Tunnelbick setup warns me right off that
"Warning: This VPN may not connect in the future.
The OpenVPN configuration file for 'client' contains these OpenVPN options:
• 'comp-lzo' was deprecated in OpenVPN 2.4 and has been or will be removed in a later version
You should update the configuration so it can be used with modern versions of OpenVPN.
Tunnelblick will use OpenVPN 2.4.6 - OpenSSL v1.0.2q to connect this configuration.
However, you will not be able to connect to this VPN with future versions of Tunnelblick that do not include a version of OpenVPN that accepts the options."
Once i push past it and try to run the vpnn i get the message:
"Tunnelblick was not able to load a system extension that is needed to connect to client."
Any workarounds or do i need a different router?
Message 1 of 2
schumaku
Guru
Re: Tunnelblick was not able to load a system extension
Tsk, tsk, tsk @NaderA - outdated OpenSSH and outdated OpenSSH config generation, too. Business Router this is supposed to be please?  Shame on you, Netgear!
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 2186 views
  • 0 kudos
  • 2 in conversation
Announcements
