Orbi WiFi 7 RBE973
Reply
WAC540 Firmware Upgrade - SSID2+ Deleted
jakesims
Follower
Hello,
I have a WAC540 using the local web interface for management and after I updated the firmware to 9.5.6.4; it deleted the wireless SSID2 and 3. I've had this problem several times in the past after upgrading the firmware, and usually if I reset the device, they eventually show up in the interface again, or I am able to add them again.
This time however, the UI seems to hang when I try to add the missing SSID2. I can see the SSID available, but it's nowhere in the UI to be found. It's super frustrating, even after performing a reset via the Maintenance => Reset => Restore Defaults, I am not able to add back in a second SSID.
Any suggestions? Thanks!
Model: WAC540|Insight Managed Smart Cloud Tri-band 4x4 Wireless Access Point
Message 1 of 2
RaghuHR
NETGEAR Expert
Re: WAC540 Firmware Upgrade - SSID2+ Deleted
Hi @jakesims
Please download the detailed logs from the monitoring page. You can upload into any drives and send me a link to download via PM.
We will check and update.
Thanks,
Raghu
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1045 views
  • 0 kudos
  • 2 in conversation
Announcements
