Orbi WiFi 7 RBE973
Reply
Orbi RBR750 Cant see parental controls
sterob1
Follower
I cant see parental controls in my app, I have updated my firmware, nothing.  Then did a factory reset on the router and satellites - reset everything from the beginning, deleted my app and re-installed and still no parental controls in the app or visible in the Basic tab when I login to my router on the internet via 192.168.1.1 - any ideas?
Message 1 of 2
Re: Orbi RBR750 Cant see parental controls
@sterob1 wrote:
I cant see parental controls in my app....
Which one – iOS or Android?
Which parental controls?
Try the section for whichever you want to use.
NETGEAR Smart Home Parental Controls - NETGEAR Communities
Circle Smart Parental Controls - NETGEAR Communities
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 727 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
