mazzi_75
Jun 20, 2024Follower
Parental control not working
I have the parental control app installed and it was working fine up until 2 days ago when I installed a new modem router. Now even though ‘ bedtime’ times are still set my kids are able to access the internet . The app is not recognising that their devices are connected or recording the times they are on the internet.
I have rebooted orbi twice and rest the Orbi & tplink router & modem . I have also deleted the app and reinstalled but still nothing is working.
Please can you advise how to fix this issue.
1 Reply
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/Procedure-for-Factory-reset-of-RBS850/m-p/2367505/highlight/true#M53985
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...
