Orbi WiFi 7 RBE973
Reply
RAX50 unable to register device and parental controls gone
Retired_Member
Not applicable
Have the rax50v2 router and the parental controls set up on all zones in my house. The parental controls disappeared from my app and now I can’t adjust the time the internet turns off in the different zones and it’s still working in the background.
But I’m also getting product already registered. So that’s an issue
And when I’m trying to login to the security section of the app it’s says login with the email I’m using and try again.
Message 1 of 2
Guru
Re: RAX50 unable to register device and parental controls gone
https://community.netgear.com/t5/Nighthawk-with-WiFi-6-AX-and/Registration-and-Un-Registering-produc...
https://community.netgear.com/t5/NETGEAR-Smart-Home-Parental/Smart-Parental-Controls-Help-and-Inform...
Ensure any mobile phone MAC Address randomizers are disabled while at home;
https://community.netgear.com/t5/Nighthawk-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-...
Be sure the app is up to date:
https://community.netgear.com/t5/Nighthawk-App/New-Nighthawk-App-Versions-and-Updates/td-p/2308366/j...
Try removing the app from the mobile phone then re-install.
Try this as well:
https://community.netgear.com/t5/Nighthawk-App/Nighthawk-app-not-connecting-but-Wi-Fi-works-gt-Try-T...
Submit a bug report thru the at to get this issue to NG:
https://community.netgear.com/t5/Nighthawk-App/How-to-report-a-bug-on-the-Nighthawk-App/td-p/2134684...
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 744 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
