Reply
RBR 750 Smart Parental Controls not working (bedtime)
Mandiliv
Follower
I have had my Orbi system for about a month. With kids on holiday break, I kept noticing my Smart Parental Controls are not functioning entirely. Profiles are set. Devices are assigned. I get history info and see usage times. BUT, the bedtime is not functioning. The internet is not pausing for the devices in the profiles.
I’m new to Netgear land. I came from Google Wifi. Please be patient with me as I’m learning this more robust system.
Message 1 of 5
Guru
Re: RBR 750 Smart Parental Controls not working (bedtime)
Have you set up some IP address reservations ON the RBR for the devices your trying to control?
https://kb.netgear.com/24091/How-do-I-reserve-a-LAN-IP-address-on-my-Nighthawk-router
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX30 Mode Mode  | Wifi Router RBK963 and RBK853 Router mode | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX3/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000, EX7500/EX7700
Message 2 of 5
mywifi101
Guide
I have been having issues also with parental controls, mine do not funtion at all. I am unable to see any history on any device. I am also unable to pause any device whether it is time based or selecting to pause a device from the app.
For the comment about setting static IPs it does not make a difference in any of the results. It does not work.
Since you should be under 90 day support I would recommend contacting Netgear. I have had mine for almost a year. Hopefully a mod can see this and provide us input.
RBR750
V4.6.5.14_2.0.54
Message 3 of 5
mywifi101
Guide
For those who are encountering this issue:
After I factory reset my device SPC is working correctly again. I am able to pause and see device history.
Note: If you backup your device settings, you will need to restore them prior to activating SPC though the Orbi app. I performed device setup through a web browser and then reconfigure the Orbi app to activate SPC.
Message 4 of 5
Palvyre
Are your bedtimes working? If I manually pause it works, but the bedtimes aren't doing anything.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1514 views
  • 1 kudo
  • 4 in conversation
Announcements
Orbi WiFi 6E
