Orbi WiFi 7 RBE973
Reply
SPC-ACT-FAIL RBR850
zaide
Tutor
SPC-ACT-FAIL RBR850
I have the RBR850 and one satellite. My parental controls on the app recently stopped working at the end of November. I then updated the firmware to v4.6.14.3_2.3.12.
I have:
  • reinstalled the app 5 times
  • factory reset the router
  • reset the modem
  • reset the router
  • unplugged from power
  • tried to solve this with 3 techs over chat
  • described the level 3 support script described in the forums.
Please help!
Message 1 of 4
Guru
Re: SPC-ACT-FAIL RBR850
I would reach out to NG support for this issue.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
@Blanca_O @KevinLiT
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode  | Wifi Router RAXE500 and RBKE963; Router mode | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX30/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000, EX7500/EX7700
Message 2 of 4
zaide
Tutor
I have reached out multiple times to netgear support. Unfortunately it hasn't been resolved yet.
Firmware version for router and satellite: V4.6.14.3
Modem is: Netgear Nighthawk CM2000
The cable we are using is a high quality cable (just double checked).
Message 3 of 4
zaide
Tutor
Hello - I've opened 5 cases, and I can't get this resolved, no matter how many times I factory reset the router. This is so frustrating.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1162 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
