- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Stuck with parental control -
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have a situation in which I am stuck.
I have Orbi RBR50, firmware and app are the latest. I had parental control turned on, which expired. I tried to purchase a subscription from the app, it says "This plan is not available", there is no way I can purchase a subscription.
Now I want to disable parental control, there is no way to do it. The app doesn't have an option to turn it off.
Then I tried to unpause it, and this doesn't work because my profile list has too many devices ( Netgear automatically adds every device it sees in my wifi network, and this gets big over time) and complains about having more than 20 devices in the list for which I need a subscription.
Then I try to connect to the router web interface using the local IP address/orbilogin.com/orbilogin.net, and I am not allowed as it says "This device is blocked by access control in the router".
I tried seeking help from Netgear, and for this, I need a support subscription! Apparently, no customer support is available for their existing customers who don't have support subscription.
I am basically stuck, come on @netgear do something about it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Stuck with parental control -
Yes, if you're outside of 90 days and not in a subscription plan, you have to pay for support.
Have you tried a simple factory reset/reinstall? might be the fastest option
