- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
4TB+4TB+2TB+2TB= 3,6TB????
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hallo habe vier Festplatten eingebaut, 2x4TB und 2x2TB und bekomme als freien Speicher 3,63TB genannt? Kann das sein??? Liegt das an RAID6? Was muss ich ändern?
I have two 4TB Harddisks and two 2TB Harddisks. Free Space is 3.63TB. How can it be? Is RAID6 the reason? What can I do?
Best regards
Ralf
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: 4TB+4TB+2TB+2TB= 3,6TB????
Are you sing X-RAID or FLEX-RAID?
In X-RAID configuration, the above should give a volume size of ~7.x TB.
Can you screenshot the volumes page for us? "System" --> "Volumes".
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello rtrogemann,
Although it is on XRAID, it is currently using RAID6. Did you add 2 disks to the existing volume at the same time? Do you have full backup of the files? If not and you can still access files, please back up.
- Mark as New
- Bookmark
- Subscribe
- Permalink
No, I don't have backups - but it's ok. And yes, I did exchange 2 volumes mostly at the same time. What do I have to do to get the full capacity?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello rtrogemann,
If it's okay with you, access the boot menu then factory reset the NAS with the disks in so it will format the disks and allow you to create a new volume using XRAID which normally it uses RAID5 automatically. See this RAID calculator as a guide.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I can't see the pics as they're not approved (which is annoying btw), but maybe the user disabled X-RAID, created the RAID6 volume, and re-enabled X-RAID.
Anyway, the only one to get back to a RAID5 is to destroy the volume and recreate one.
