Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
4TB Disks for Ultra 2+
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-02-05
04:34 AM
2014-02-05
04:34 AM
So at present the HCL only lists the Hitachi 7k4000 HUS724040ALE640 as compatible.
Now this is the Ultrastar device (HUS) and retails at around £250 a disk? The Ultrastar range is offered with a 5 year warranty and 2.0 million hours MTBF. The HCL only indicates the Warranty as 3 years. So are they referring to the Deskstar product HDS724040ALE640 which is offered with a 3 year warranty and retails at around £182 (I can actually get in Ireland for €183 incl VAT)?
So what is the difference between the UltraStar and DeskStar 7K4000 disks - is it just the 2.0 million hours MTBF for Enterprise level usage? Now sure I need the disks warranted for 228.3 year's use.
It sounds like WD Red 4TB have issues. I currently have a pair of 6 month old 2TB WD Red in my Duo (at 83% capacity), that are working fine, and an old (~5 years) pair of 1TB WD Blacks now in USB enclosures connected to an old NSLU2 as backup NAS (at 89% capacity each)
Is there a better 4TB disk for the Ultra 2+? I have bought this NAS 2nd hand, with a 2GB memory upgrade, so there is no Warranty issues to consider.
Thanks,
Simon.
Thanks,
Simon.
Ultra 2+ with Pro 2 extensions - 8TB volume (WD Reds)
Ultra 2 with Pro 2 extensions - 6TB volume (WD Reds)
Duo - 2TB volume (WD Reds)
Linksys NSLU2 (unslung) 2 * 1TB volumes (WD Black's)
USB 3.0 1TB WD Blue
APC UPS USB connection to Duo with network monitor
USB 3.0 1TB WD Blue
Message 1 of 5
Labels:
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-02-05
04:39 AM
2014-02-05
04:39 AM
Re: 4TB Disks for Ultra 2+
Maybe the SeaGate 4TB NAS disk would be a good buy.
Useful links: Sending Logs|My ReadyNAS Gear|FAQ|Hardware Compatibility List|Docs: Setup Guide, Manual|Downloads|Unofficial Tips|GPL|MDGM on Twitter|MDGM's Unofficial Guides
NB: A ReadyNas is not an excuse not to have a backup. Fire, theft, multiple disk failures, other hardware failure, floods, user negligence etc. can all result in loss of data.
How to contact NETGEAR Technical Support | Australia: 1300 361 254 / Other Numbers|Online Submission
Unofficial Guide for Moving from Sparc ReadyNAS to x86 ReadyNAS|Using Gmail with the ReadyNAS|XRAID Volume Size Calculator
Message 2 of 5
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-02-06
04:12 AM
2014-02-06
04:12 AM
WDC now provides a supported tool for changing the head parking thresholds on the newer WDC Reds. With that tool, it is probably ok to use them also.
The Seagate drives are a little newer, and have slightly better specs.
Be careful on mix/match with the Seagates though. I think some of the drives in their NAS lines have a slightly lowered number of sectors from usual. The sizes need to match exactly to get mix and match. I recall a posting in this forum on that subject, you might search for it.
Message 3 of 5
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-02-08
05:37 AM
2014-02-08
05:37 AM
Thanks for the pointers - looking at the Seagate NAS 4TB disks, which are currently on Amazon.co.uk for £133.90 each.
Will be buying a pair together, so no mix/match issues.
Heh - why doesn't the HDD manufacturers etc. provide pairs, 4 & 6 'matched sets' from the same manufacturing run with sequential SNs, for NAS usage?
Also ordered a Fractal 'Silent Series' 92mm Fan to replace the OEM item (Delta afb0912hh), which has a rated noise of 38 dB-A (max 41) whereas the Fractal (FD-FAN-SSR2-92) is rated at 12.5 dB-A
I replaced the OEM in my Duo with a 60mm Fractal one and the drop in operating noise was significant, though being much smaller was probably having to work much harder than the 92mm in the Ultra Plus.
Message 4 of 5
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-02-08
05:49 AM
2014-02-08
05:49 AM
It's probably better to get drives from different manufacturing batches; that is, buy them from different resellers and at different times.
This way you potentially avoid getting a set of drives that all have a similar flaw that manifests itself later in a number of drives at the same time.
I generally don't buy more than 2 at a time.
Back it up. Use UPS.
Infrant Readynas NV+ | Readynas Ultra 6 Plus | Readynas 316
Message 5 of 5
