Reply
AOL.com Alert Tests fail with 5008010001 error
hojni
Just upgraded to firmware 6.10.6 and attempted an alert test using my AOL.com email address.  Received the "Cannot send a test mesage.  Check authentification settings.  Code 5008010001"
I realized that I have not been receiving alerts for a while - probably since Verizon tightened AOL security a while back.  Is there any fix, workaround or way to send a message via my SMS provider?
Message 1 of 3
Accepted Solutions
hojni
Re: AOL.com Alert Tests fail with 5008010001 error
Got notifications to AOL working again.  Had to go into AOL security and generate a 3rd-party app password.  Instructions here:
      https://help.aol.com/articles/Create-and-manage-app-password
Message 3 of 3
All Replies
Marc_V
NETGEAR Moderator
@hojni
Were you able to check your AOL settings? If they made security enhancements there might be a setting that is preventing ReadyNAS to access.
Have you tried recreating the settings? or rechecking with Verizon/AOL? Have you tried using a different provider? like gmail perhaps?
HTH
Marc_V
NETGEAR Community Team
It's what you do that defines you
NETGEAR Community User Guidelines
Model: ReadyNAS-OS6|
Message 2 of 3
hojni
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 557 views
  • 0 kudos
  • 2 in conversation
Announcements
