- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Adding Disks 3,4 to existing ReadyNAS Volume
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hey Everyone!
Quick question -- maybe it's simple, but I want to make sure I'm understanding X-RAID correctly:
I currently have a RN424 with 2x8TB.
I also have 2x4TB each with data that is being copied to the NAS. Once this copy is done, I'd like to integrate the 2x4TB into the current RAID.
If I add these two disks, can the current volume be expanded without reformatting the 2x8TB (containing the precious data copied from the 2x4TBs)? (I'm assuming the disks being added need to be formatted -- but will that mess with the data on the current volume?)
In other words:
DISK A - 8TB (currently in RAID) - DO NOT WANT FORMATTED
DISK B - 8TB (currently in RAID) - DO NOT WANT FORMATTED
DISK C - 4TB (adding to RAID) - OK to format
DISK D - 4TB (adding to RAID) - OK to format
Just want to double check before pulling the trigger (since I dont have redundancy until the NAS is in place.) Thank you so much for your help!
All the Best,
Jordan
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Adding Disks 3,4 to existing ReadyNAS Volume
@JordanBeckett wrote:Quick question -- maybe it's simple, but I want to make sure I'm understanding X-RAID correctly:
I currently have a RN424 with 2x8TB.Once this copy is done, I'd like to integrate 2x4TB into the current RAID.
Generally speaking this can't be done. The exception would be if the RN424's data volume was 2x4TB in the past. If you aren't sure if that was the case, you can download the log zip file from the web ui, and copy/paste the contents of mdstat.log into a reply.
There's a fairly detailed (and somewhat technical) explanation here: https://community.netgear.com/t5/Using-your-ReadyNAS-in-Business/Readynas-RAID-5-quot-protection-quo...
But the rules are that you can:
- always replace a disk with one of the same size
- always add (or replace) a disk with one that is at least as large as the biggest disk in the array
- add a disk that is the same size as one that used to be in the array
- replace a disk with one that is the same size as one that used to be in the array, as long as it is at least as large as the disk you are replacing.
If you have 2x8TB XRAID, then you do have redundancy (the array should be RAID-1).
Assuming that you can't add the 4 TB drives to your existing volume - your other options are:
- purchase a third 8 TB drive and add it to the array. The NAS will convert the volume to RAID-5, and you'll have 16 TB of available storage.
- switch to flexraid, and add the two 4 TB disks as it's own 2x4TB RAID-1 volume. You'll end up with 12 TB of storage (and still have protection against single drive failure).
- switch to flexraid, and add the two 4 TB disks as two 4TB JBOD volumes. You'll end up with 16 TB of storage (but would have no protection against failure of one of the 4 TB drives).
Options 2 and 3 both require you to put some shares on the new volume[s] - possibly moving them from the existing 2x8TB one.
Personally I'd go with option 1.
One thing to keep in mind - RAID redundancy is useful, but isn't enough to keep your data safe. The only way to do keep it safe is to back it up.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hey StephanB, thanks for the help!
That RAID breakdown really helps. I understand how X-RAID determines capacity vs protection much better now.
It sounds like adding 4TB drives at this point won't add much in the way of protection OR capacity, so I'll take your advice and pick up a couple 8s and use the 4s as a backup.
I'm still unclear about whether the current NAS volume will need to be rebuilt when I add drives 3 and 4 (4x 8TB). Though I suppose it doesn't matter since the data on the 4TB is already my backup.
I know what I need to do at least 🙂 Thank you so much for taking the time to help!
All the Best,
Jordan
- Mark as New
- Bookmark
- Subscribe
- Permalink
Since I'm looking to increase protection as well as capacity, I'm going to bite the bullet and buy 2x8TB drives.
