× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Best / quickest / least painful way to “vertically” expand a NAS when having a full data backup
berillio
Hello Forum
This is – somewhat – a follow up to “vertical expansion of the wrong NAS” (https://community.netgear.com/t5/New-ReadyNAS-Users-General/vertical-expansion-of-the-wrong-nas/m-p/... ) from almost 2 years ago; in the sense that the hardware in use is still the same. That is:
NAS A – RN214a, 4x 4TB,  8.14TB used, 2.69TB free, FW 6.10.3
NAS B – RN214b, 4x 8TB, 19.13TB used, 2.69TB free, FW 6.10.3
NAS C – RN424,  4x 8TB, 20.80TB used, 1.01TB free, FW 6.10.4 Hotfix1
But as I am constantly needing more data space, few days ago I bit the bullet and bought 2x 12TB Seagate Ironwolf, with the intention of fitting them to the the RN214a (the “wrong” NAS in that previous post), simply because adding just 2 disks would give me an extra 8TB, which should be ample for now. I could expand again at a later stage.
Has anybody used such a big array in an RN214?
My first concern was if the RN214 can accommodate 4x 12TB disks (in terms of power required), but according to the datasheet, the ST12000VN0008 is even less demanding that the 8TB counterpart, and I should be safe: still, there is no substitute for (other people’s) experience.
But my basic question is whether I should be doing a “conventional” vertical expansion ( ie. remove the oldest 4TB, hot insert the 12TB, wait for resync, then remove/replace the other 4TB, wait the TWO extra resync (one for the volume to be redundant again, the other to increase the size of the array) or, considering that I have a full back up of the data (on a 10TB disk on a pc), do something else entirely, i.e. to ditch the existing Volume and creating a New Volume from scratch.
For example, I could:
  1.  backup the existing configuration, then remove all the disks (if I was deleting the Volume at that moment, the disks would be wiped out and a would lose a 2nd parachute backup);
  2. insert one 12TB, create the new Volume, and copy all the data;
  3. insert the 2nd 12TB disk. If I have chosen X-RAID, the NAS should copy over the data making a mirror image (RAID1, I guess).
  4. insert one (wiped out/reformatted) 4TB disk. The Nas should then resync going into RAID5 (I presume that at this stage, with a dissimilar size disk, the Nas would create the md126 and uses a different RAIDs for md127 and md126)
  5. insert the 4th  (4TB) disk and wait for another resync.
OR
Could I just  do (1), then add One disk, create the Volume structure, copy half a dozen of small text file (one in each share) and the add all the disk as I said earlier? This way resync time would be a matter of seconds . When I then copy the FULL DATA, it would be striped across the array as it is copied. That should be far less demanding on the drives
OR
could I just add one disk, then the 2nd, 3rd and 4th, then create the shares….
Would that be different?
Or…could I just load up all the four (wiped-out) disks and then boot up? Would that be possible/better .. or not at all possible (maybe a NAS array MUST be built in stages… I wouldn’t imagine so, it would be very time consuming for larger arrays, and on the RN424 all the disks had the same age – but then, inserting them sequentially it would only take a matter of minutes, and they may report the same age, in hours);
Incidentally, just a THERMAL concern: wouldn’t be better to place the 12TB disks in bay 1 & 4 and fit the 4TB disks in the middle, as the middle drives always tend to run a little hotter.. ? (easier done if  I choose to create the new volume from scratch, with a "conventional" expansion I would need another disk swap & resynch as the disk in Bay 2 is the the 2nd oldest disk in the existing array),
Or….
I would be better off buying another enclosure and have another NAS (but then it seems almost impossible to buy a ReadyNAS in the UK or maybe anywhere else in europe)
Just for info, disks age and usage is as follows:
on RN214a, 4x 4TB disks
Bay 1, 26 Jan 2020, 25205 h:
Bay 2, 15 May 2018, 34603 h;
Bay 3, 26 Jan 2020, 25213 h;
Bay 4,  7 Mar 2018, 36918 h.
          But I have a fresher 4TB disk with 18456 hours of use. I could use that one, easy done if I am rebuilding the volume from scratch
on RN214b, 8TB disks
Bay 1,  5 Oct 2021, 11049 h:
Bay 2, 27 Oct 2021, 11029 h;
Bay 3, 27 Oct 2021, 10901 h;
Bay 4,  4 Aug 2022,  5909 h.
on RN424b, 8TB disks
Bay 1, 29 Mar 2021, 15908 h:
Bay 2,  5 Oct 2021, 12947 h (failed and replaced);
Bay 3, 29 Mar 2021, 15908 h;
Bay 4, 29 Mar 2021, 15908 h.
Incidentally, I was advised to “test” the new drive, before installing it, so I initially run a “quick” scan of both drives on a USB adaptor; now I am testing the first of the two drives (installed on a PC on a SATA3 socket) using Victoria 5.36 (full scan sequential test); that should take another ~7h (~14h in total to scan the entire disk).
I use Victoria because I am reasonably familiar with it, it provides easy understandable informations and it seems to work; I also remember using the no-nonsense old WDDLGD, while I am not familiar with the latest versions of SeaTools and WD dashboard.
Is there any other software or test which I should run?
Thank you in advance for your advice, Berillio
p.s. if the RN214 was not considered reliable enough to be fitted with the 12TB units, I could, of course, replace 2 of the 8TB disk in the RN424 with the 2 12TB disks, and then put the 8TB disks in the RN214a. But a) I do not have a backup of the data on the RN424 and b) all of that would require 3 resynch of the 10TB array and 3 resyinch of 20TB array, i.e. an extremely intense disk activity.
Message 1 of 9
Guru
Re: Best / quickest / least painful way to “vertically” expand a NAS when having a full data backup
I don't have an RN214, but I have two 14 TB drives in an RN202, and have not had any issues.  One is a WD Red Pro, the other is a Seagate Exos.  It should be ok.
Any particular reason you are still on 6.10.3 (2020 firmware)?
Don't do this. Trying to add a smaller disk to the array will usually fail outright.  There are a few cases where I've seen the NAS add smaller disks when you install the second one, but you would lose capacity.
If this worked with 2x12TB+2x4TB you'd end up with 16TB instead of 20TB.
The flaw in your reasoning here:  md127 normally is built from partitions on each disks (sda3, sdb3, sdc3, sdd3).  md126 is normally built from partitions on the two largest disks (sda4, sdb4 for example).  So for this to work properly, the two biggest disks need 4 partitions (sda1 for the OS, sda2 for swap, sda3 for md127 and sda4 for md126). sda3 is the size of the smallest disk (4 TB in this case), sda4 fills the remaining space (8 TB in this case).
But when you start with 12 TB drives, the NAS will create a 12 TB sda3 partition.  It will not attempt to repartition the 12 TB drives when you add the smaller ones.  So at best you wouldn't end up with RAID-5.  You'd end up with two RAID-1 groups instead - which wastes space.
Also, as far as disk stress goes, it's the repeated syncs that creates the disk loads (and takes the extra time needed when upgrading all four disks).  Your process doesn't reduce the number of syncs.  If you want to start over, the way to do that is to insert all four disks and do a factory default.  That will build the volume in the most efficient way (with the least disk i/o).
I think you are over-thinking this.  In this situation I'd just do the normal vertical expansion - hotswapping one disk with the 12 TB one, waiting for the resync to complete, and then hotswapping the second one.
RAID runs "below" the file system - creating virtual disks (md126 and md127) that the file system uses.  The resync time doesn't depend on how full the file system is - RAID neither knows that nor cares.  It is exactly the same process for an empty volume as a full one. So no time savings if you do this.
Generally when I am replacing disks for expansion, I remove the oldest.  So I'd replace disk 4 with a 12 TB model, and after the resync completes I'd replace disk 2.
If you want to use the younger spare, you could also replace the disk in either bay 1 or bay 3 with that disk.  I'd do that first, just to get it out of the way.
Not sure how much it matters.  If you want to do that, you could power down and reorder the disks before you begin (swapping disk 1 and disk 2, so the oldest drives are in slots 1 and 4).  Then boot up and proceed with the replacements.
If Victoria has a full erase test, then I'd also run that.  Seatools does have that test (dashboard does not).
My reasoning here is that I have sometimes had new disks pass the full read scan, but fail the write.  (I've also had disks that fail on the read scan, and pass on the write).
Message 2 of 9
Guru
Thinking about this a bit more...  wanting to use the younger 4 TB drive in addition to the two 12 TB drives might change the calculus some.
One option is to power down the NAS, and replace the three disks - setting the ones you remove aside. Leave the one disk you want to continue to use in the system. Then do a factory default from the boot menu, set up the NAS again, and restore the data from the backup.  Personally I'd also upgrade the firmware to 6.10.9.
Advantages are
  1. gives you a completely clean system
  2. gives you a fallback if something goes horribly wrong (as the NAS will boot up with the original volume if you power down and reinsert the three disks you remove - leaving the fourth slot empty)
  3. rebuilds with minimum disk i/o
Personally I don't think (3) is a major consideration in your case, as you are replacing healthy disks and have a full backup.
Message 3 of 9
berillio
Hello Stephen, TY for coming back.
First of all an apology, disks were tested using a SATA2 socket – not a SATA3 (I always meant to say that, I just got the digit wrong).
                       “Any particular reason you are still on 6.10.3 (2020 firmware)?”
“if it ain’t broke, don’t fix it”, my NASs are all working fine. But I take the advice to upgrade to 6.10.9 – I presume that the best time to do it is after I do the “Factory Default”, in the procedure you recommend in your 2nd message.
Also.. change of program, I just bought 2x 12 TB Ironwolf Pro  – I should have them Tuesday.
So I wonder if it wouldn’t make more sense to have the 4x 12TB array in the RN424, which is a better machine.
 I know that the RN424 is Intel based and the RN214 is arm based, but I do not know if I can simply and safely move an array from an Intel based platform to an arm based platform.
If that is possible, I  could:
  1. Save the config, remove the array from the RN424 (4x 8TB) and put it in the RN214a, and check if it reads the array.
  2. Refit the RN424 with the 12TB drives, do a factory default, upgrade to 6.10.9 if so recommended (it has 6.10.4 Hotfix 1).
  3. Copy over all the data from the RN214 which has the original array.
  4. Then on the RN214a, I would save the configuration and delete the existing volume;
  5. Maybe do a factory default? Would that be necessary/advisable? (That array always had 8TB drives), then upgrade the FW to 6.10.9;
  6. Copy over the existing backup of the data which is on my PC (currently testing both 12TB IronWolf, (Victoria v5.37, W-R-V test since yesterday, ~11h to finish)
That.... assuming that an arm platform has no issues with an array created on an Intel platform. If that is NOT the case, I guess that I would follow the same in procedure, but the RN214 ( save config, remove drives, refit drives, factory default, firmware update, copy over the backup.
Same size drives, no resynch necessary, easy.
I simply need to wait for the new drives and test them. Fingers crossed...
Message 4 of 9
Sandshark
Sensei
Yes, you can move an array form an OS6 ARM unit to an OS6 Intel unit (and vice-versa).  There is a very slight difference in the way the drives are formatted for the ARM version, the OS partition is EXT instead of BTRFS, and that will remain, but it's not really a factor you need to worry about.
Message 5 of 9
Guru
FWIW, SATA3 has a benefit with SSDs, but SATA2 is still faster than mechanical disks, so that makes no real difference.
As @Sandshark  says, you can. But you do need to uninstall your apps first (and reinstall them after the NAS boots up on the new platform).
Message 6 of 9
berillio
Hiya Forum,
Further update. The ebay seller was actually local, so the morning after my post I could collect the disks from his address, came back home and started testing them both, simultaneously. One failed the Quick Test and continued failing the WRV (WriteReadVerify, I presume) test repeatedly; the other one seemed ok, but eventually proved to be only slightly faster than the standard 12GB Ironwolf (non Pro) previously tested, and also has SIX times as many blocks in the 100-250ms range than the non Pro.
I considered that not safe enough and I returned both disks today (the WRV test finished @7:01:05 this Monday morning).
So, back to the original plan, which was the 2x12TB + 2x4TB array,
I will follow the procedure suggested by StephenB the 3rd post.
Message 7 of 9
berillio
Update again – plus some kind of snag  😞
I created the 2x12TB + 2x4TB array as planned, went through the single double-resyinch (2x ~36h), upgraded FW and everything worked out perfectly fine.
After copying all the data which was on the NAS original array, I copy-moved there all the data which was scattered around on various 4TB USB drives, other disks on another PC, and the RN424.
Then I started consolidating the dataset moving all various folders in a more organised manner.
This is when I realised that - guess what, I was running out of space on the new array.
I initially panicked, thinking that I had misconfigured the lot and created like 5TB of snapshots (like it happened before, some while ago); (only at that moment I realised - it hadn’t occurred to me before - that the snapshots are created for an entire share and not a subfolder).
So, thinking that the share where I moved the data had enabled snapshots, I created another share, made sure that snapshots were not going to be created there and started moving data in this new share (using the web interface, which I am not familiar with – infact it was probably the FIRST files/folder movement I ever done using it).
Few minutes later I realised that ACTUALLY, I had only 32 GB of snapshots in total in the entire array, and they were in some other shares, so that was NOT why I was running out of space
So I reasoned that, obviously, I did not do my sums right in the first place and underestimated the space I needed (well, I was never running out of space, but I would have ended up with three NASses which would have been 75/80% full, and I would have never had the space to start having some proper backups etc.).
So I decided to get the other 2x 12TB and create the full, proper array. I stopped all that moving to the new share operation, as it was unnecessary at this moment, and started moving the data OFF the new 214a array to the old locations, so I could scrap the new array entirely, create a new one directly with 4x12TB and save all that double resyinching exercise (2x2 resynchs of 36h would have been lengthly...).
This morning I got the 2x 12TB SG IronWolf, from the same “official” (3y warranty) retailer I bought the first couple, planning to ReadWriteVerify test them as soon as possible, and started looking of where to move the data, according to where I had the space, wishing to avoid the USB disks etc.
It was only then that I realised that – SHOCK HORROR – I have lost data, and a conspicuous amount too, ~2.5TB (in one dataset, three years of data, 2018, 2019, 2020 have disappeared entirely and 700GB from the 2021 folder are missing).
And of course I don’t have any snaphots, that folder was (properly, lol) configured NOT to have snapshots.
Of course, if the data was on a normal disk, there are plenty of programs which would allow me to undelete/recover the data. But on a RAID… well, I know that there a few programs which can reconstruct failed/corrupt array (never been able to recover any data with the shareware versions, tho’), but this is a different situation, the array is (presumably) not corrupt, I simply cancelled/aborted the “moving” operation without realising that ONLY the data which had been transferred would have survived (if this is what happened). This is why one should have a snapshots/backup policy in place.
At moment I am moving data out of the array. That may take over a day or two if not more. I am also testing the new disks, circa 30h remaining.
Once all the (transferred) data has been moved back, since I still have the original full backup of the data which was on the 214a before doing anything, I could do a factory default start from scratch again. Unless there is a way to recover those lost subfolders, that is.
Incidentally, all the data which has been lost came out of the RN424, and I am not moving any data there yet (but I might have written ~100GB of new data in the last few days). Needless to say, there are no snapshots, but 5.1TB of free space, ~25%. If I wish to leave that space alone, I have the 3x 4TB disks which were de-commissioned from the 214a which could be wiped clean if necessary; I also have 3.3TB free-able on a PC and ~2.95TB  on an USB.
Message 8 of 9
berillio
Update on the previous post.
I MIGHT have found the missing data, it MIGHTY have been an incomplete transfer to the RN214a in the first place.
Currrently consolidating the data, fingers crossed.
Also the two new 12TB completed the ReadWriteVerify test successfuly earlier this morning.
Consolidating / backing up of the data may take another 24/36/48h. I will update ASAP
Message 9 of 9
Top Contributors
Discussion stats
  • 8 replies
  • 815 views
  • 0 kudos
  • 3 in conversation
Announcements
