× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
CPU temperature exceeded safety threshold. (83 C).
Gajanan11
Hello,
We are using ReadyNAS 524X there show of massage CPU temperature exceeded.
But think was room temperature is 25C.
So please suggest any solution on it.
Thanks & Regards
Gajanan
Message 1 of 4
Guru
Re: CPU temperature exceeded safety threshold. (83 C).
Install a external USB fan for additional cooling.
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode  | Wifi Router RBKE963 and RBE973 | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX30/CAX80/CM1100/CM1200/CM2000, Orbi: CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, MK93S, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000,
Message 2 of 4
Sandshark
Sensei
  1. Obviously, insure the fan is operating properly.
  2. Make sure it's not situated on a shelf or too close to a wall such that fan exhaust comes back to the inlet or fan backpressure is affected.
  3. If not already selected, change the fan setting to cool
  4. Check the fan blades for dust.  If it's collecting some, then so are the internal components.  Open the unit and clean it out with compressed air.  NOTE:  don't let the fans free-wheel, it can harm the bearings if you drive them faster than the fan is rated.  Use a pencil or something to keep the blades from rotating.
Message 3 of 4
Gajanan11
Thaks for reply.
we will check & let you know.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 459 views
  • 1 kudo
  • 3 in conversation
Announcements
