- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Can I move my hard drive from a RN102 to a RN312 and keep all the contents?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm not sure if the title is quite clear on what I mean, but I didn't want to get too wordy.
I've got a RN102 with a 4TB drive in that is fairly full (about 75%). I've just bought a RN312 as an upgrade, and wondered if I can simply move the hard drive over and keep all the data somehow, without having to buy another hard drive as an intermediate storage?
I realise it might be a long shot, but as the main difference that I could see was just the processor I thought it might be worth checking.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Can I move my hard drive from a RN102 to a RN312 and keep all the contents?
Hi SisyphusBond,
Welcome to the community!
This can be done and you're right about the processor difference between RN102 and RN312. Migrating or moving the disks is possible just ensure that you have the same firmware version on both or newer on the RN312 chassis.
Let me know if you have further questions.
Kind regards,
BrianL
NETGEAR Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
@BrianL2 wrote:
The only way is to have your all data backed up somewhere, insert the drives to the new RN312 and perform factory reset. You're right about the processor difference between them. Migrating or moving the disks is not possible.
Actually it is supposed to work (disk migration from RN100 to RN300 or better). Was this feature deprecated?
- Mark as New
- Bookmark
- Subscribe
- Permalink
This feature was not deprecated.
When you take your disks from RN100 and place them into RN300, during boot, the chassis acknowledges that the disks came from a different architecture and it will update the files to the chassis version. Make sure your chassis are on the same version, or the RN300 is on the latest and the RN100 is on a version lower than the RN300, so it will do an update.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi SisyphusBond,
I suggest you leave it until the LED becomes stable. I couldn't tell how long but the migration should be flawless between these models.
Let me know if you have further question.
Kind regards,
BrianL
- Mark as New
- Bookmark
- Subscribe
- Permalink
Well it's been going for 8 hours, so far...
- Mark as New
- Bookmark
- Subscribe
- Permalink
I had another thought. Could it be because I'm not trying to migrate it to a pure "diskless" system? The manual only takes about migrating to a diskless NAS.
I had installed one temporary hard drive to upgrade the firmware, and then just swapped the disks. Could it perhaps be that the 312 is still expecting the temporary drive to be there somehow?
Can I somehow downgrade it back to "diskless"? I can't seem to use the "destroy" volume option in the settings with a single drive in there. Factory reset I would also assume to reboot and start formatting the temporary drive already in there?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Reading here:
I noticed a bit about OS Reinstall from the boot menu. Would that work, perhaps?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Did you power down, remove the temporary, add the original disks, and then power up?
- Mark as New
- Bookmark
- Subscribe
- Permalink
@StephenB wrote:
@SisyphusBond wrote:I had another thought. Could it be because I'm not trying to migrate it to a pure "diskless" system? The manual only takes about migrating to a diskless NAS.
That's exactly what I did, yes.
I tried to reinstall the OS after adding the original disk. That seems to have had some success, as the 312 now boots and I can see the files through ReadyCloud. I can't for the life of me seem to get through to it with anything on my LAN, thought.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Did you try looking at the status in RAIDar? (if it shows up, confirm the IP address).
Does it respond to ping?
- Mark as New
- Bookmark
- Subscribe
- Permalink
To be honest I've now put in an order for another drive, as I was getting impatient (my kids DVDs have been ripped to a Plex Server on the NAS) and wanted to ensure delivery promptly.
I'll do my best to test your suggestion anyway though, in case it can help anyone else who might encounter the same problem.
I should add that it appears on my router's "Attached Devices" correctly as far as I can tell. It even accepts the forced IP address I set if I activate it. I just can't seem to access it with anything except network drives.
I tried accessing it with SSH via Putty too. It asks me for my password but when I put it in the terminal closes abruptly.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Was ssh enabled? You are using root for the username?
- Mark as New
- Bookmark
- Subscribe
- Permalink
SSH was enabled, yes. Though I think I was using "admin" to log in (it's been a while since I last tried it, so I was rusty).
I'll give that a shot with "root" when I try checking it with RAIDar (probably this evening).
- Mark as New
- Bookmark
- Subscribe
- Permalink
Okay. I've just tried both of those things. Using SSH with root worked fine, and the NAS is visible to RAIDar (both after reinstalling the OS after swapping the drives). I still can't access the admin page, or any of the apps installed (e.g. Plex, Bittorrent Sync, etc.) from the direct links I had set up.
I'm not too sure where that leaves me or if it helps. I'm not too bothered personally, as having been pushed into buying another drive I'm planning on using it when it arrives tomorrow anyway. I've no objection to running more tests in the meantime if it's liable to be of any help to others though.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I suspect the apps would be a problem - the NAS itself can migrate to x86, but the apps would remain arm. Probably we should have said to uninstall the apps first.
The apps might also be the reason the web page won't start.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@StephenB wrote:I suspect the apps would be a problem - the NAS itself can migrate to x86, but the apps would remain arm. Probably we should have said to uninstall the apps first.
Ah. I wonder if that's it, as Plex at the very least is an ARM specific version I think.
I may give that a try today before going for the extra drive. Would it lose all the settings and so forth, though?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Netgear can probably tell you how to remove the apps with ssh. Hopefully one of them will chime in.
You would lose plex settings (and the other app settings too).
- Mark as New
- Bookmark
- Subscribe
- Permalink
@StephenB wrote:Netgear can probably tell you how to remove the apps with ssh. Hopefully one of them will chime in.
I might as well give it a try to find out, given that I'm probably planning on a new drive and fresh start anyway.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Just as a brief update, I ran out of time to check this and the drive has now been formatted. So my apologies to anyone who comes to this thread looking for answers to a similar question, but hopefully it at leaves something worth trying if you do.
