× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Compatibility Lists?!?!?!
mjlarrabee
Follower
OK, so I understand that it's and older model, and that "any 2tb drive on the compatability list" will work - But the compatability list for the RND4000  is simply NOWHERE TO BE FOUND.  30 Minutes of searching is (rather, should be) more than enough to find a list of compatible drives for a product.
Can anyone direct me to the ACTUAL list of drives compatible with the RND4000 v1?  Please don't suggest a particular drive, please don't re-link me to the compatability list selection page (the drive model isn't there.  for whatever reason..), just a link to drives that the RND4000  will support should be fine.  Thanks!
Model: RND4000 |ReadyNAS NV+ v1|EOL
Message 1 of 2
Guru
Re: Compatibility Lists?!?!?!
Go here: https://kb.netgear.com/20641/ReadyNAS-Hard-Disk-Compatibility-List
Enter Legacy in the pulldown, and a second pulldown will appear.  Then select ReadyNAS NV+, which is another name for the RND4000 v1.
That will give you the list you want.  It hasn't been updated for many years (since 2012 I think).
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1668 views
  • 0 kudos
  • 2 in conversation
Announcements
