- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Copying data from ReadyNAS104 to Seagate Innov8
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi there,
I am using RN104 with the latest OS. Have close to 7TB of data, which I am planning to back-up to Seagate Innov8(USB3.1 Gen 2) hard drive. Is there any way to connect the Seagate to ReadyNAS. Or is there a better way to copy the data from RN104 to Seagate Innov8 without much of a manual intervention.
TIA.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
@rajamani_v wrote:
I tried that as well, but the problem is Innov8 cannot get enough power from the ReadyNAS. Hence, it is not recognised in ReadyNAS.
You basically have two options.
One is to find a charger that can act as a power injector (passing through your data connection to the NAS).
The other is to connect the disk to a PC, and to the backup over the network.
The second option is probably easiest.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Copying data from ReadyNAS104 to Seagate Innov8
Hi @rajamani_v
Welcome to the Community!
You can connect your Seagate Innov8 to the USB 3.0 port of your RN104, unfortunately you will not be able to use the Type-C USB, an adapter will be needed (USB Type C femaile to USB 3.0 male)
You can then follow the guide on this link on transferring/backing up files from your ReadyNAS to USB Disk.
Make sure you have enough space on your USB disk so all data will be backed up.
Hope this helps!
Regards
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Marc,
Thanks for your response.
Regards
Raja
- Mark as New
- Bookmark
- Subscribe
- Permalink
If correct Innov8 is being powered by battery, are you certain it's fully charged?
Also, desktop drives require 12V which was not available directly until the USB 3.1 Type-C specification came about.
ReadyNAS RN104 has USB 3.0 and USB 2.0 ports which is not enough to power your Seagate Innov8 if this is the case.
You may have to check with the manufacturer why is it not getting any power.
Regards
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Unfortunately, I have to go with the second option only. Not sure how many hours/days it's gonna take to back up that amount of data 😞
- Mark as New
- Bookmark
- Subscribe
- Permalink
You can do incremental backups after the first one - using the file modification date and size as the triggers to update old files. FreeFileSync is one utility you could look into there.
It's hard to predict the speed - lots of small files will take longer than one larger file for example. And the Innov8 is an SMR disk - one of the weaknesses inherent to SMR is it's sustained write performance. But if you are using a wired gigabit connection to the PC, you'll get the same speed over the network that you'd get connecting it directly to the NAS. It's probably best to back up one share at a time, rather than trying to do everything in one backup run.
