× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
DC plug size for ReadyNAS duo v2 (RND2000)
JochemOnline
Hi community,
I need to replace my power adapter, and unfortunately Netgear does not provide them separately. So I'm stuck with a third party solution, which raises two issues:
  1. What is the exact plug size for the DC connector? I have tried both 5.5x2.5 and 5.5x2.1 mm, and both do not fit the socket properly.
  2. The original European adapter came with an earthed 230V plug. Most replacement adapters have an unearthed plug. Would that be a problem?
Looking forward to your replies.
Cheers,
Jochem
Model: RND2000v2|ReadyNAS Duo v2 Chassis only
Message 1 of 5
Guru
Re: DC plug size for ReadyNAS duo v2 (RND2000)
It should be 5.5mm/2.1mm.  FWIW, there is one here that claims to be compatible: https://www.amazon.de/Adapter-RND2210-200NAS-ReadyNAS-NU60-H120500-I1-332-10122/dp/B08LDSWBRV
No.
Message 2 of 5
JochemOnline
Hi Stephen, thanks for your reply. I've seen other brands too that claim to be compatible, but how can I be sure? It would be best if someone who's been using such adapter can confirm it fits properly. I'd rather prevent having to order multiple models and having to return all but one.
Message 3 of 5
Guru
Hopefully someone will.
My own Duo's power brick is still working.  But I don't have a tool that can measure the plug size accurately.
Message 4 of 5
Sandshark
Sensei
I have used third party supplies with a 5.5x2.5mm connector without issue.  I do always look for ones that are labled for CCTV camera use, not just LED lighting, as they typically have better power regulation.  I have been happy with the Kaystar brand since the brand I used to get is no longer available.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1375 views
  • 0 kudos
  • 3 in conversation
Announcements
