Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Disk drive diagnostic tool are they definitive ?
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-10-29
12:26 AM
2011-10-29
12:26 AM
Hi All
Can anyone let me know if the disk drive diagnostic tools are definitive. If I run the Western Digital Data LifeGuard Diagnostics tool on my 4 x 2Tb WD-20EARS CAVIAR GREEN 2TB 64MB 7200 SAT and they all came back as passed, can I yes 100% that the disk are ok ?
Or is there a possibly they could still be bad ?
Thanks
Alan
Thanks
Alan
Message 1 of 16
Labels:
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-10-29
03:49 AM
2011-10-29
03:49 AM
Re: Disk drive diagnostic tool are they definitive ?
Vendor thresholds for bad sectors are much higher than the ones I personally use. So I always look at the smart data (which Lifeguard will show you) in addition to their pass/fail. If you see a trend of increasing reallocated sectors, then the drive is almost certainly failing even if it hasn't reached the vendor threshold yet.
alan27 wrote: Hi All
Thanks
Alan
I have tested drives I knew were failing, but the vendor tools still passed them. Waited another week, and then they failed. So in my experience, if the vendor tools report a fail, then the drive is certainly bad. However, if they report a pass, it does not guarantee that the drive is good.
Are you having issues with your drives? Maybe you could post the details.
Message 2 of 16
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-10-29
04:07 AM
2011-10-29
04:07 AM
Also what version of RAIDiator is on your NV+? You need 4.1.7 or later for compatibility with those drives.
Message 3 of 16
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-10-29
07:19 AM
2011-10-29
07:19 AM
Hi mdgm
It's all part of an ongoing issue I have with my NV + not booting which I have a thred running here for : viewtopic.php?f=20&t=58275
Just trying to elimate as much as possible. 3 of the 4 drives have been tested so far and all have passed, just disk 1 to go , but didn't look at the increasing reallocated sectors part. So will have to put them all back in and have a look once disk one has finished. (7 hours to go 😞 ) thanks for the info yes I am on 4.1.7. The disk are only 10 month old just find it hard to believe 4 disk fail at the same time, but looks like there ok ..... Maybe.
Once this disk is done I'll pull the report for each disk and post them here, so you can see if that's ok , if thats ok .If you get a spare min to have a look at my main issue that would also be most appreciated 🙂
Thanks again for you time and help
Alan
Alan
Message 4 of 16
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-10-29
07:25 AM
2011-10-29
07:25 AM
I'm just a user like you and don't know much about SMART. Feel free to post the drive SMART stats (I wouldn't post drive serial numbers though, so edit those out).
The vendors tests are the best tests available but they're not guaranteed to pick up if a drive has issues.
Message 5 of 16
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-10-29
08:41 AM
2011-10-29
08:41 AM
There is an interesting paper on SMART here: http://static.googleusercontent.com/ext ... ilures.pdf
Message 6 of 16
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-10-29
10:32 AM
2011-10-29
10:32 AM
Thanks guys, will follow your advice thanks agin
Message 7 of 16
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-10-31
04:04 AM
2011-10-31
04:04 AM
Ok so out of the 4 x 2Tb WD-20EARS CAVIAR GREEN 2TB , Disk 1 failed. Disk 2, 3, 4 passed . But I’m very worried that the remaining disk are on their way out , as they were all purchased at the same time , maybe a bad batch ? any advice you could give me here would be most appreciated.
Here is the SMART logs for each disk
Disk 1 , this is the one that failed
Disk 2 ,
Disk 3
Disk 4
What I find odd ( to my untrained eye ) is Disk 1 looks ok in the logs , no errors like 2,3,4 but yet that’s the one the failed .... also 2,3,4 are almost identical 12 errors ? hmmm? I have also read about ATA Error Counts , Reallocated Sector Counts and Load Cycle Count as ones to look out for as a guide to if you hard drive is on its way out ....
Is 12 ATA errors bad ? is a Load Cycle Count of disk 2: 362613 Disk 3: 421549 Disk 4: 423058 something I should be worrying about ? these hard drives are only 10 month old .
Any help / advice you can give me here would be most appreciated.
Alan
=== START OF INFORMATION SECTION ===
Device Model: WDC WD20EARS-00J2GB0
Firmware Version: 80.00A80
User Capacity: 2,000,398,934,016 bytes
Device is: Not in smartctl database [for details use: -P showall]
ATA Version is: 8
ATA Standard is: Exact ATA specification draft version not indicated
Local Time is: Thu Oct 27 09:48:32 2011 WEST
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status: (0x84) Offline data collection activity
was suspended by an interrupting command from host.
Auto Offline Data Collection: Enabled.
Self-test execution status: ( 0) The previous self-test routine completed
without error or no self-test has ever
been run.
Total time to complete Offline
data collection: (40260) seconds.
capabilities: (0x7b) SMART execute Offline immediate.
Auto Offline data collection on/off support.
Suspend Offline collection upon new
command.
Offline surface scan supported.
Self-test supported.
Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 2) minutes.
Extended self-test routine
recommended polling time: ( 255) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0
3 Spin_Up_Time 0x0027 172 169 021 Pre-fail Always - 8400
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 37
5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0
7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0
9 Power_On_Hours 0x0032 091 091 000 Old_age Always - 7198
10 Spin_Retry_Count 0x0032 100 253 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 253 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 35
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 34
193 Load_Cycle_Count 0x0032 077 077 000 Old_age Always - 369604
194 Temperature_Celsius 0x0022 120 107 000 Old_age Always - 32
196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 29
198 Offline_Uncorrectable 0x0030 200 200 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 0
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
No self-tests have been logged. [To run self-tests, use: smartctl -t]
SMART Selective self-test log data structure revision number 1
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
Disk 2 ,
ATA Version is: 8
Local Time is: Thu Oct 27 09:48:35 2011 WEST
been run.
data collection: (39600) seconds.
command.
power-saving mode.
3 Spin_Up_Time 0x0027 171 167 021 Pre-fail Always - 8441
9 Power_On_Hours 0x0032 091 091 000 Old_age Always - 7209
193 Load_Cycle_Count 0x0032 080 080 000 Old_age Always - 362613
194 Temperature_Celsius 0x0022 117 106 000 Old_age Always - 35
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0
ATA Error Count: 12 (device log contains only the most recent five errors)
CR = Command Register [HEX]
FR = Features Register [HEX]
SC = Sector Count Register [HEX]
SN = Sector Number Register [HEX]
CL = Cylinder Low Register [HEX]
CH = Cylinder High Register [HEX]
DH = Device/Head Register [HEX]
DC = Device Command Register [HEX]
ER = Error register [HEX]
ST = Status register [HEX]
Powered_Up_Time is measured from power on, and printed as
DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes,
SS=sec, and sss=millisec. It "wraps" after 49.710 days.
Error 12 occurred at disk power-on lifetime: 12 hours (0 days + 12 hours)
When the command that caused the error occurred, the device was active or idle.
After command completion occurred, registers were:
ER ST SC SN CL CH DH
04 51 01 00 00 00 40 Error: ABRT
Commands leading to the command that caused the error were:
CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name
b0 d6 01 e0 4f c2 40 00 12:30:28.355 SMART WRITE LOG
b0 d6 01 e0 4f c2 40 00 12:30:28.197 SMART WRITE LOG
b0 d6 01 e0 4f c2 40 00 12:30:28.041 SMART WRITE LOG
b0 d6 01 e0 4f c2 40 00 12:30:27.884 SMART WRITE LOG
b0 d6 01 e0 4f c2 40 00 12:30:27.726 SMART WRITE LOG
Error 11 occurred at disk power-on lifetime: 12 hours (0 days + 12 hours)
b0 d6 01 e0 4f c2 40 00 12:30:27.568 SMART WRITE LOG
Error 10 occurred at disk power-on lifetime: 12 hours (0 days + 12 hours)
ec 00 01 01 00 00 a0 00 12:30:27.388 IDENTIFY DEVICE
Error 9 occurred at disk power-on lifetime: 12 hours (0 days + 12 hours)
Error 8 occurred at disk power-on lifetime: 12 hours (0 days + 12 hours)
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Disk 3
ATA Version is: 8
Local Time is: Thu Oct 27 09:48:38 2011 WEST
been run.
command.
power-saving mode.
3 Spin_Up_Time 0x0027 169 165 021 Pre-fail Always - 8550
9 Power_On_Hours 0x0032 091 091 000 Old_age Always - 7206
193 Load_Cycle_Count 0x0032 060 060 000 Old_age Always - 421549
b0 d6 01 e0 4f c2 40 00 12:30:28.665 SMART WRITE LOG
b0 d6 01 e0 4f c2 40 00 12:30:28.507 SMART WRITE LOG
b0 d6 01 e0 4f c2 40 00 12:30:28.350 SMART WRITE LOG
b0 d6 01 e0 4f c2 40 00 12:30:28.194 SMART WRITE LOG
b0 d6 01 e0 4f c2 40 00 12:30:28.036 SMART WRITE LOG
b0 d6 01 e0 4f c2 40 00 12:30:27.878 SMART WRITE LOG
ec 00 01 01 00 00 a0 00 12:30:27.698 IDENTIFY DEVICE
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Disk 4
ATA Version is: 8
Local Time is: Thu Oct 27 09:48:43 2011 WEST
been run.
data collection: (41880) seconds.
command.
power-saving mode.
3 Spin_Up_Time 0x0027 168 164 021 Pre-fail Always - 8575
9 Power_On_Hours 0x0032 091 091 000 Old_age Always - 7170
193 Load_Cycle_Count 0x0032 059 059 000 Old_age Always - 423058
194 Temperature_Celsius 0x0022 120 109 000 Old_age Always - 32
b0 d6 01 e0 4f c2 40 00 12:30:30.259 SMART WRITE LOG
b0 d6 01 e0 4f c2 40 00 12:30:30.101 SMART WRITE LOG
b0 d6 01 e0 4f c2 40 00 12:30:29.944 SMART WRITE LOG
b0 d6 01 e0 4f c2 40 00 12:30:29.787 SMART WRITE LOG
b0 d6 01 e0 4f c2 40 00 12:30:29.630 SMART WRITE LOG
b0 d6 01 e0 4f c2 40 00 12:30:29.472 SMART WRITE LOG
ec 00 01 01 00 00 a0 00 12:30:29.291 IDENTIFY DEVICE
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Alan
Message 8 of 16
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-10-31
05:16 AM
2011-10-31
05:16 AM
Did your NAS come with firmware older than 4.1.7? If so that would explain why you have those ATA errors. As for the Load Cycle Count don't worry about it, those numbers are meant to be high.
What does your partition.log look like?
Message 9 of 16
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-10-31
09:15 AM
2011-10-31
09:15 AM
Hi Mdgm
Thanks again, for taking the time to look and help, yes your right , it came with 4.1.6, last Dec then upgrade 2 ish month after that to 4.1.7 . cool so there looking good at the mo 🙂
Here is my Partition.log
What can you tell from that then ? (hope all is good there also)
Disk /dev/hdi doesn't contain a valid partition table
Disk /dev/hdc: 2000.3 GB, 2000388448256 bytes
255 heads, 63 sectors/track, 243200 cylinders, total 3907008688 sectors
Units = sectors of 1 * 512 = 512 bytes
Disk identifier: 0x00000000
Device Boot Start End Blocks Id System
/dev/hdc1 2 4096001 2048000 83 Linux
Partition 1 does not end on cylinder boundary.
/dev/hdc2 4096002 4608001 256000 82 Linux swap / Solaris
Partition 2 does not end on cylinder boundary.
/dev/hdc3 4608002 3906992305 1951192152 5 Extended
/dev/hdc5 4608003 3906992305 1951192151+ 8e Linux LVM
Disk /dev/hde: 2000.3 GB, 2000388448256 bytes
/dev/hde1 2 4096001 2048000 83 Linux
/dev/hde2 4096002 4608001 256000 82 Linux swap / Solaris
/dev/hde3 4608002 3906992305 1951192152 5 Extended
/dev/hde5 4608003 3906992305 1951192151+ 8e Linux LVM
Disk /dev/hdg: 2000.3 GB, 2000388448256 bytes
/dev/hdg1 2 4096001 2048000 83 Linux
/dev/hdg2 4096002 4608001 256000 82 Linux swap / Solaris
/dev/hdg3 4608002 3906992305 1951192152 5 Extended
/dev/hdg5 4608003 3906992305 1951192151+ 8e Linux LVM
Disk /dev/hdi: 2000.3 GB, 2000388448256 bytes
Message 10 of 16
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-10-31
02:14 PM
2011-10-31
02:14 PM
This confirms your unit came with firmware older than 4.1.7.
Due to the lack of 4k sector alignment you may be experiencing poor write performance.
Message 11 of 16
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-11-01
02:42 AM
2011-11-01
02:42 AM
Now you mention it , it’s not the quickest no , that was something I was planning to look into later, do you know how I can fix this and align the sectors ? I’m guessing it’s a factory reset using 4.1.7 or 4.1.8 ?
Message 12 of 16
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-11-01
03:02 AM
2011-11-01
03:02 AM
Yes, upgrading to 4.1.7 or later (you've already done this), verifying update is successful (i.e. new version shown in Frontview and/or RAIDar), a backup and a factory reset is the way to fix it.
Of course there are other performance tweaks you can make too. See ReadyNAS Performance Expectations
Message 13 of 16
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-11-01
03:50 AM
2011-11-01
03:50 AM
your a star thanks for your help mdgm , will do that 🙂
Message 14 of 16
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-11-01
09:03 AM
2011-11-01
09:03 AM
alan27 - one never really knows when a drive may fail. You may not experience a failure in drives 2-4 for a long time. When I set up my NV+ over 4 1/2 years ago with two 500GB Seagates, one failed in a little over a month. The second one was still going strong when I upgraded the drive size last summer and it had over 25,600 hours on the drive. Hopefully you will not have another drive failure for some time, but one just never knows.
Message 15 of 16
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-11-02
10:31 AM
2011-11-02
10:31 AM
Thanks for the advice guys. I know where I stand now on this, I guess the best thing to do is make sure you have a good backup 😉
Message 16 of 16
