Orbi WiFi 7 RBE973
Reply
Error: System volume root's usage is 81%.
Doug6392
Guide
I received this error this morning, and found some worthwhile previous discussion, especially from @StephenB. I initiated an SSH connection and found the only very oversized file in root was "syslog". Will clearing the log correct this? I probably haven't cleared the log, maybe since the unit was new. (There are apparently 873 pages of entries.)
I'm very new to Linux, and simply followed the instructions posted to a similar query back in 2018. I don't want to break anything, and according to Netgear's site, any paid support I was once entitled to has ended.
I have attached the SSH session, which hopefully will assist.
Thanks in advance for any assistance.
Model: RN10400|ReadyNAS 100 Series 4- Bay (Diskless)
Message 1 of 5
Accepted Solutions
Guru
Re: Error: System volume root's usage is 81%.
@Doug6392 wrote:
Thanks for the quick reply. Sorry to be a pain, but how do I truncate the file?
This should work:
echo -n > /var/log/syslog
Make sure you log in as root (using the NAS admin password).  I am thinking your earlier attempt might have failed because you logged in as admin.
Message 4 of 5
All Replies
Guru
You must have installed an app that includes rsyslog.  syslog isn't part of the readynas application at all.  So as far as the NAS is concerned, you certainly can truncate it.
FWIW, /var/log on my main NAS looks like this:
4.0K alternatives.log
2.7M apache2
108K apt
0 audit
28K btmp
0 clamav
4.0K dbbroker.log
144K dpkg.log
0 faillog
2.7M frontview
0 fsck
48M journal
20K lastlog
0 news
236K proftpd.log
860K proftpd.log.old
3.1M readynasd
1.1M samba
8.0K tallylog
804K wtmp
60M total
Message 2 of 5
Doug6392
Guide
Thanks for the quick reply. Sorry to be a pain, but how do I truncate the file? I tried removing it via basic Linux commands I found online but was not successful.
Message 3 of 5
Guru
This should work:
Message 4 of 5
Doug6392
Guide
@StephenB wrote:
This should work:
That did the trick - many thanks!
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 2316 views
  • 1 kudo
  • 2 in conversation
Announcements
