- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Expand ReadyNAS 422 from one 4TB drive with second 2TB drive
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have existing ReadyNAS 422 at firmware 6.10.6 with one 4TB drive X-RAID JBOD.
Would like to add a second drive. It is a 2TB drive.
Thought I could add to the 2nd slot for 6TB of total JBOD capacity without any RAID protection.
I can't see that it will let me do this.
Is this limitation of Netgear or am I doing something wrong?
Thanks!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Expand ReadyNAS 422 from one 4TB drive with second 2TB drive
I think you can (though it's been a while since I played with this). BTW, one risk when you span two drives w/o RAID protection is that when either drive fails you will lose all the data on both. So it's not a setup that I recommend.
You need to first turn off XRAID - if there is a green bar on the XRAID control, click on it to switch to flex raid.
Then you can expand the volume by creating a second RAID group on the 2 TB disk, and concatenate the two groups.
If you can't figure out how to expand it, you can create a second volume on the smaller drive, and move some of your shares there.
- Mark as New
- Bookmark
- Subscribe
- Permalink
You do need to turn off XRAID to accomplish that.
- Mark as New
- Bookmark
- Subscribe
- Permalink
can you give me some points on how to do this without turning off XRAID?
thank you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
It cannot be done with XRAID enabled.
XRAID will
- ignore any drive smaller than 4 TB
- Give you RAID-1 mirroring with any drive 4TB or larger (with no increase in capacity).
