Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
File system question
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-05-19
07:39 AM
2012-05-19
07:39 AM
I have a Stora NAS which is dead, I would now like to replace it with a ReadyNAS Duo V2. How do I transfer my data? From what I understand these products use different file systems?
/Stefan
/Stefan
Message 1 of 7
Labels:
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-05-19
07:48 AM
2012-05-19
07:48 AM
Re: File system question
You will need to transfer the data across the network, either from backup or by getting the Stora working again. You cannot take the disk from the Stora and install it into the ReadyNAS, although you may be able to mount it in your computer using various tools and then copy the data over the network to the new ReadyNAS.
I'm not familiar with the Stora (it's a different product line than the ReadyNAS and not supported under these forums).
Message 2 of 7
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-05-20
08:15 AM
2012-05-20
08:15 AM
My Stora is really dead (RIP). The only thing I can think of is to buy another Stora (peferably used), move the date on the network, install the new ReadyNAS, and then transfer the date there. Then I end up with a Stora I don't need anymore 😞
Message 3 of 7
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-05-20
05:04 PM
2012-05-20
05:04 PM
Something like this might work: http://www.ufsexplorer.com/rdr_xfs.php BTW the Stora forum is http://forum1.netgear.com/forumdisplay.php?f=106
Message 4 of 7
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-05-21
02:21 AM
2012-05-21
02:21 AM
What file system is used by ReadyNAS Duo/NV+ V2?
Message 5 of 7
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-05-21
02:22 AM
2012-05-21
02:22 AM
StephenB wrote: Something like this might work: http://www.ufsexplorer.com/rdr_xfs.php BTW the Stora forum is http://forum1.netgear.com/forumdisplay.php?f=106
Thanks! This sure looks like a solution.
Message 6 of 7
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-05-21
02:28 AM
2012-05-21
02:28 AM
lofstrom wrote: What file system is used by ReadyNAS Duo/NV+ V2?
Different RAID format is used. The ReadyNAS Duo/NV+ v2 uses the EXT4 filesystem. The only arrays that can be migrated to a Duo/NV+ v2 are ones created using another Duo/NV+ v2.
Message 7 of 7
