× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Filesystem still has errors (ReadyNAS 3200)
Manuel_Baena
Hello, I have ReadyNAS 3200 with data volume failures.
After a disk failed, the server restarted and after running automatic checks, it was unable to recover the volume data system.
I put below part of logs messages. Any ideas to recover it? Thanks.
Inode 6074141 is too big.  Truncate? yes
Block #656409612 (2845762991) causes directory to be too big.  CLEARED.
Block #656409613 (1413754900) causes directory to be too big.  CLEARED.
Block #656409614 (710395238) causes directory to be too big.  CLEARED.
Block #656409615 (2605083730) causes directory to be too big.  CLEARED.
Block #656409616 (627206157) causes directory to be too big.  CLEARED.
Block #656409617 (835375234) causes directory to be too big.  CLEARED.
Block #656409618 (1721141576) causes directory to be too big.  CLEARED.
Inode 6074141 has illegal block(s).  Clear? yes
Illegal block #656409619 (4210973595) in inode 6074141.  CLEARED.
Error storing directory block information (inode=6074141, block=0, num=200617629): Memory allocation failed
/dev/c/c: ***** FILE SYSTEM WAS MODIFIED *****
e2fsck: aborted
***** File system check performed at Mon Nov 19 09:30:10 CET 2018 *****
fsck 1.42.12 (29-Aug-2014)
/dev/c/c: One or more block group descriptor checksums are invalid.  FIXED.
/dev/c/c: Group descriptor 4 checksum is 0x0000, should be 0xf858.
/dev/c/c: UNEXPECTED INCONSISTENCY; RUN fsck MANUALLY.
    (i.e., without -a or -p options)
Model: ReadyNASRN12P1220|ReadyNAS 3200 24TB (12 X 2TB Enterprise)
Message 1 of 10
Guru
Re: Filesystem still has errors (ReadyNAS 3200)
I think you will need data recovery.  Netgear has a recovery service here: https://kb.netgear.com/69/ReadyNAS-Data-Recovery-Diagnostics-Scope-of-Service
You could also connect the disks to a Windows PC and try R-Studio for Windows.  https://www.r-studio.com/
Message 2 of 10
Manuel_Baena
How can I get int touch with technical support? Through the link (https://kb.netgear.com/69/ReadyNAS-Data-Recovery-Diagnostics-Scope-of-Service) I don't get any email to contact or other contact form.
Message 3 of 10
Guru
my.netgear.com is the place to start for all paid support requests.  You don't want Gearhead, you want to go into the registration page and ask for support for your registered ReadyNAS.
Message 4 of 10
Manuel_Baena
Ok, thanks
Message 5 of 10
Manuel_Baena
We have been tryng to purchase support through my.netgear.com
The system indicates the device is already registered. If we try to access with the user who registered the product in 2009  (jbustamante@ebd.csic.es) we get "user not recognized". The serial numbre of the device is : 25T19AYT0006A
It is necessary to buy 1 year support before getting a diagnostic?
Message 6 of 10
Guru
The system indicates the device is already registered. If we try to access with the user who registered the product in 2009 ... .
Is this a used NAS?  Or was it registered by someone in your organization (who perhaps has left)?
Message 7 of 10
Manuel_Baena
Yes, this is NAS server that has problems and is owned by the public administration.
This NAS was registered in 2009 by another user, and its access data isn't validated in the login form.
Message 8 of 10
Guru
Netgear's warranty is not transferrable (though it's expired anyway), and their policy is that they don't provide support for used equipment.
If the orginal user who registered the NAS was part of your organization, then support can change that registration to be linked to your email.  If that user wasn't part of your organization, they won't do that - and they won't provide paid support.
You might want to PM @Marc_V (using the envelope icon in the top right of the forum), and give him more details (exactly what your organization is, and whatever other history he needs).
Message 9 of 10
Manuel_Baena
Yes, this user is from same organization.
Thanks
Message 10 of 10
Top Contributors
Discussion stats
  • 9 replies
  • 1091 views
  • 1 kudo
  • 2 in conversation
Announcements
