× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Reply
Harddrive Question
Draax
Harddrive Question
Hello,
I have a question about the harddrives outside the Netgear nas.
Im running raid 1 on 2 drives, is it posible to remove one drive and plug it into my computer to access the data (running windows) if so do i need any software?
Thanks in advance!
Message 1 of 5
Guru
Re: Harddrive Question
You will need software - windows does not recognize the drive format.
Linux Reader works with the v1, I don't know if it also works with the v2. http://www.diskinternals.com/linux-reader/
Message 2 of 5
Draax
Awesome, ill replay with the result's thanks a lot in advance!
Message 3 of 5
Guru
Shut down the NAS, especially don't hot-insert after you try this. The NAS will wipe the drive and then rebuild the RAID array if you do that.
Message 4 of 5
Draax
Hello again and thanks for a quick reply.
I recive an error when i try open "volume 6 (linux RAID partition)" error: Can't open disk: Volume6 RAID partition) Check the disk and try again.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 4185 views
  • 0 kudos
  • 2 in conversation
Announcements
