- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- « Previous
- 1
- 2
- Next »
Help troubleshooting rndp6000
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Help troubleshooting rndp6000
Only me. Could I add an extra lan to usb and have two lan ports for double the transfer rate?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I don't think Windows has much (if any) support for link aggregation.
What you could do is get a small multigig smart switch, and then put a 10 gig card in the PC. If it's a laptop or an all-in-one, you could maybe use a 10 gig USB-C/Thunderbolt adapter - though I have no personal experience with those. Cost would be in the $300-$400 range for the switch and PC NIC. You do need a cat-6 cable for the switch->PC leg at least.
On the NAS end, you'd set up the switch to use a static LAG and the NAS to use round-robin.
Not sure I'd do this with a Pro-6 though. It's more advantageous if you have a NAS with 10 gig built in (RN52x or better).
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks. So is multichannel SMB not an option?
Patrick
- Mark as New
- Bookmark
- Subscribe
- Permalink
The NAS has no controls to enable it, and I believe it's disabled by default.
Also to get it to work you need to manually adjust the route tables on at least the NAS. https://www.reddit.com/r/homelab/comments/5p6gy6/my_experience_with_samba_and_smb_multi_channel/
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks.
I can get a LAG compliant device. But do I need a thunderbolt device for 10G?
I already have one usb3 ethernet 1 gig port and another on the laptop motherboard 1 gig.
I could run one cat6 to each and do round robin bind for eth0 and 1?
Patrick
- Mark as New
- Bookmark
- Subscribe
- Permalink
When I googled, I only saw thunderbolt external adapters.
AFAIK Microsoft doesn't include support for link aggregation in "consumer" versions of windows - it's only in Windows Server. There might be some third party solutions out there I guess.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok. Got it.
When you said you only saw thunderbolt adapters -- you mean for 10G, right? why not use two usb2 1G adapters since total is 2G not 10G or does this require a single adapter with 2G or greater?
So if I'm using Windows 10 -- even though it doesn't support LAG -- I can still use a Thunderbolt 3 10G and LAG managed switch and i can support both lan ports via static or dynamic link aggregation? Why is round robin used in bonding not 802.3ad in the ethernet bonding settings?
Is the limitation software (windows 10 OS) or hardware?
Here's a switch that might work?
https://www.amazon.com/gp/product/B00HGLVZLY/ref=ox_sc_act_title_1?smid=A3VFRVXM4EMKV6&psc=1
and
adapter?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Because Windows doesn't support link aggregation.
LACP is it's own mode. The only thing you can configure on the NAS is the hash mode (which doesn't affect performance much). LACP was designed for "trunking" multiple client connections between switches (or between a switch and a server). With 2 gigabit NICs it can deliver two gigabit data flows to different clients, but it won't deliver a 2 gigabit data flow to a single client. A static LAG in the switch and round-robin in the NAS will deliver a 2 gigabit data flow.
and
adapter?
The GS105E doesn't support link aggregation. The GS108T does. Though if you want 10 gigabit from the PC you'll need a multigig switch like the Nighthawk SX10.
The Thunderbolt adapter is one that I saw too. I've never used one of those, so I don't have any personal experience with them.
- « Previous
- 1
- 2
- Next »
