× NETGEAR will be terminating ReadyCLOUD service by April 1st, 2023. For more details click here.
Reply
Hot Swap RAID5 4TB disks with 10TB
Alexjccim
Apprentice
Hello Everyone,
I have a RN214 4-Bay configured in RAID5.
  • Disk1: Seagate IronWolf 6TB: Purchased 2020
  • Disk2: Seagate IronWolf 6TB: Purchased 2020
  • Disk3: Seagate IronWolf 4TB: Purchased 2016
  • Disk4: Seagate IronWolf 4TB: Purchased 2016
After completion of the monthly Disk Test, I received this error:
"Detected increasing uncorrectable error count: [16] on disk 3 (Internal) [ST4000VN008-2DR166, WDH0VBLG] 16 times in the past 30 days. This condition often indicates an impending failure. Be prepared to replace this disk to maintain data redundancy."
My Question: What are my steps to "Hot Swap" Disk3 & Disk4 with two Seagate IronWolf 10TB drives?
I appreciate any insights you can offer.
-Alex
Model: RN214|4 BAY Desktop ReadyNAS Storage
Message 1 of 5
Accepted Solutions
Guru
Re: Hot Swap RAID5 4TB disks with 10TB
We do recommend making sure you have a backup, as the RAID array isn't redundant during resyncs, and the process does stress the disks.
The process is simple - hot swap disk 3 first, as it is showing signs of failure.  The array will then resync in two steps (and the second step should expand your volume by 2 TB).
After the resync, hot swap disk 4.  That will resync in three steps - the second step will expand your volume by another 2 TB, and the third will expand it by 4 TB.
Message 2 of 5
All Replies
Guru
Message 2 of 5
Alexjccim
Apprentice
Stephen,
I appreciate the fast response.  Yes, I have a USB backup on the NAS.  I'll follow-up upon completion.
Thank you,
-Alex
Message 3 of 5
Alexjccim
Apprentice
Stephen,
Everything worked perfectly.  Thank you!
-Alex
Message 4 of 5
Guru
Great!  Thx for following up.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1011 views
  • 1 kudo
  • 2 in conversation
Announcements
