- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
How to Replace Defective Drive in ReadyNAS 4220X
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have a ReadyNAS 4220X configured with RAID6/X-Raid using 8 3TB drives.
An error was reported from channel 8, volume status changed to degraded, there was a suucessful re-sync and channel can back online but still with degraded volume status
Currently, all drives have green light status but I assume there is still an issue with channel 8 drive & that it needs to be replaced
I can't find clear guidance on how to replace a defective drive in this situation
Can anyone point me to documentation that shows the steps to replace a defective drive or give clear direction based on their personal experiences?
Thanks!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: How to Replace Defective Drive in ReadyNAS 4220X
I always recommend hot-swapping the drive - that ensures that the OS "sees" the removal and reinsertion, and doesn't have to make assumptions on what it happening.
In this case I'd download the log zip (or use ssh) to see what is going on with the drives. Looking at mdstat will give you some idea on whether a RAID group is still missing a drive. Also look for indications of drive errors in the smart stats, system.log, kernel.log, etc. It might not be drive 8 that failed to sync.
Personally I also test my drives in a Windows PC (using vendor tools) before adding them to the NAS. That includes running the full ("long") non-destructive test, as well as a full write test. Unfortunately, WD's dashboard utility no longer has the write zeros test - I have an older copy of their Lifeguard program that does. Both tests have found OOB failed drives for me (and sometimes one has detected the failure, but not the other).
I've recommended NAS-purposed and enterprise-class drives for some years now - many consumer drives in this size range now use SMR technology, which is not a good choice for ReadyNAS. Avoid current WD Red drive models, as they are all SMR. Red Plus drives are fine, as are Ironwolf.
