Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- « Previous
- Next »
IPv6
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-12-17
10:21 AM
2011-12-17
10:21 AM
Re: IPv6
sphardy - if the ISP is implementing it for home users, wouldn't that mean that the gateway would need to support it, but the home network wouldn't. If the home network would have to support it, then there is going to be a boatload of networked equipment that will no longer work. Not just older ReadyNAS units, but PCs, modems, printers etc. I can hear the screams of anguish now.
Message 51 of 69
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-12-17
10:25 AM
2011-12-17
10:25 AM
Re: IPv6
It would be nice if they'd list IPv6 support in the product comparison table; I'm guessing it's still not there anywhere, and as a result, I'm building a nexenta appliance instead of upgrading to a newer readynas.
Message 52 of 69
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-12-17
10:39 AM
2011-12-17
10:39 AM
Re: IPv6
IPv6 is needed because IPv4 (the current IP protocol) has run out of room - all the available addresses have been allocated to the various regions, and ISPs are in the process of using them up. While NAT has allowed us to last this long, and to continue stretching it out for a while, IPv6 is a much better solution, and getting it up and running in parallel with IPv4 ("dual stacking") avoids doing under the gun when you *have* to. Granted, that's a long ways out, but the ball is rolling and the sooner everyone supports IPv6, the easier the transition will be. The one thing to watch out for is that with IPv6, you don't have the inherent basic firewall that NAT provides, so you have to make *sure* you are blocking incoming traffic you don't actually want at your firewall.
Message 53 of 69
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-12-17
10:55 AM
2011-12-17
10:55 AM
Re: IPv6
PapaBear wrote: sphardy - if the ISP is implementing it for home users, wouldn't that mean that the gateway would need to support it, but the home network wouldn't. If the home network would have to support it, then there is going to be a boatload of networked equipment that will no longer work. Not just older ReadyNAS units, but PCs, modems, printers etc. I can hear the screams of anguish now.
The gateway would typically be provided by the ISP and if it supports IPv4 on the backend then all is fine, but a) users may want to take advantage of IPv6 in which case all equipment needs to support it and/or b) I believe I've seen reports of at least one ISP (Possibly Belgian, but not 100% sure) where the gateway is IPv6 only.
Message 54 of 69
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-12-17
11:01 AM
2011-12-17
11:01 AM
Re: IPv6
useopenid - All x-86 based ReadyNAS units running 4.2.16 or later support IPv6 as that was when it was added to RAIDiator. (I am running 4.2.17, but have the IPv6 assignment currently in the off position)
I fully understand the advantage of IPv6 in the WAN environment, but for the LAN in a home environment? I doubt many home networks will run out of addresses in the 192.168.1 or 192.168.0 subnets. We may have to replace old routers, but that is a far easier task than replacing all the printers and other non-compliant devices.
That may put the final nail in Windows XP as well, as I don't believe Windows XP supports IPv6.
Message 55 of 69
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-12-17
11:02 AM
2011-12-17
11:02 AM
Re: IPv6
+1 IPv6 is needed to continue to be a viable platform...at least implement it on the x86 platform.
Message 56 of 69
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-12-17
11:05 AM
2011-12-17
11:05 AM
Re: IPv6
It's only in the IPv6-only case that *everything* needs to support it. Currently, it's typical to dual stack the things that can be - the devices and applications that support IPv6 use it in preference to IPv4, those that don't just use IPv4 in blissful ignorance.
While it's true it isn't absolutely necessary for home users to switch to IPv6 exclusively, it makes life simpler if you only have to deal with one (which is one source of the inertia in switching).
XP does support IPv6 (possibly only with later SPs, not sure), but you have to use some obscure command line tools to configure it.
Message 57 of 69
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-12-17
11:10 AM
2011-12-17
11:10 AM
Re: IPv6
agconmet - It is as long as you are running RAIDiator 4.2.16 or later. Here is a screen shot of my NVX Network settings page - note IPv6 settings at the bottom.
Message 58 of 69
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-12-17
11:13 AM
2011-12-17
11:13 AM
Re: IPv6
PapaBear wrote: I doubt many home networks will run out of addresses in the 192.168.1 or 192.168.0 subnets.
Not really the point - IPv6 means every device can have a unique IP address and so (if required) be fully accessible from the internet. No need for NAT and the reserved subnets such as 192.168.x.x, no messing with port mapping/triggering and the like. In fact no need for ports as each service could have its own IP address
Consider ReadyNAS Remote: It creates a secure link by assigning an additional separate IP address to the NAS, manages access to that via the netgear proxy service with the service opening ports as required and then implementing some form of encryption to secure the data. Such a capability is built directly into IPv6
Message 59 of 69
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-12-17
12:26 PM
2011-12-17
12:26 PM
Re: IPv6
Some notes on IPv6:
- Every Windows version since Vista not only supports IPv6, but it is switched on by default, and it is the preferred protocol over IPv4 as with any IPv4 + IPv6 (dual stack) capable device. So if DNS returns an IPv4 address and an IPv6 address for a web site, any IPv6 enabled device will setup an IPv6 connection, never an IPv4 connection.
- Just type ipconfig/all in the command prompt of Vista and Windows-7, and you will see some special IPv6 addresses.
- Windows-XP can support IPv6, but you will have to install a special pack.
- Keep in mind that the IP stack of Windows-XP in general is quite poor compared to the IP stacks of Vista and later.
- IPv4 and IPv6 are not compatible. That means you will have to run a dual stack as long as you need to connect to IPv4 hosts (that will be for many years I'm afraid).
- The address space of IPv6 is indeed enormous. IPv4 is a 32 bit network, normally you would use what was called a Class-C network in your home LAN. That is a /24 network, and it leaves you with 32-24=8 bits for hosts on your LAN. These 8 bits will support 254 host addresses. IPv6 is a 128 bit network. A standard subnet with IPv6 is a /64 network. That leaves you with 128-64=64 bits for host addresses on this subnet. Compare that with the 32 bits for the entire IPv4 Internet. Normally your provider will give you a /48 network, leaving you with 128-48=80 bits of address space. Since a normal subnet is a /64 network, the remaining 80-64=16 bits can be used to set up 65536 subnets. Should be sufficient I think.
- If you're buying a new router, make sure it has IPv6! Also check if your present router supports it, or if there is a new firmware release that supports it, or ask the manufacturer if they are planning a firmware release with IPv6.
- Normally an IPv6 SOHO router will by default block all incoming IPv6 traffic, so your IPv6 equipment is quite safe.
- Android phones, and I'm sure iPhones as well, support IPv6 by default.
- If you router supports it, you can also set up an IPv6 tunnel over IPv4 (assuming your provider doesn't support IPv6 yet). It will also give you real IPv6 addresses on your home LAN.
Message 60 of 69
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-12-18
12:59 AM
2011-12-18
12:59 AM
Re: IPv6
As far as I know the Readynas Sparc software is build with the Debian Linux kit for 32 bit Sparc cpus. There is some support for IPv6 in this Linux distribution kit, as you can see here: http://packages.debian.org/search?arch=sparc&searchon=names&keywords=ipv6. I just don't know if this is sufficient for the Readynas developers. It would be nice if we can get a response from them.
Message 61 of 69
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-12-18
04:44 AM
2011-12-18
04:44 AM
Re: IPv6
From a quick look it appears that's for Sparc 64-bit not Sparc ReadyNAS which use 32-bit CPUs.
Also it's not for the sarge distribution used by the Sparc ReadyNAS.
edit: Sparc ReadyNAS use sarge distribution
Message 62 of 69
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-12-18
11:02 AM
2011-12-18
11:02 AM
Re: IPv6
maxblack wrote:
sphardy wrote: Some ISPs are now implementing IPv6 for home users and so user home equipment must support it too to be functional. As for benefits - every device can have a unique address, so no need for NAT etc, plus increased security features are the main points for us end users
Thanks, I'm gonna study-up on it some more!
There is a few ISP's out there that provide various IPv6 tunnels allowing you to set up IPv6 access to the Internet without your ISP providing native IPv6.
I have used Hurricane Electric Internet Services (http://he.net/) free 6in4 tunnel (http://www.tunnelbroker.net/). They give you a routed /64 and an optional routed /48 IPv6 address space for your tunnel.
They also have a free simple training/certification that you can go through.
I began using a Hurricane Electric tunnel on an Ubuntu system until my firewall supported IPv6. I have also been able to set it up on an Apple Airport Extreme.
Message 63 of 69
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-12-18
11:11 AM
2011-12-18
11:11 AM
Re: IPv6
I see. It seems the Etch distribution is outdated, and has been replaced by the Lenny distribution. However it also seems that the Etch distribution had an IPv6 stack.
The descriptions of all Debian versions refer to the same page about the Sparc cpu: http://www.debian.org/ports/sparc/. Unless I'm mistaken the Sparc distribution is a 32 bit version, and you have to make a special build for the Sun4u and Sun4v cpus that support a 64 bit address space, if you want to use more than a 32bit address space.
Message 64 of 69
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-12-18
11:57 AM
2011-12-18
11:57 AM
Re: IPv6
CharlesLaCour wrote: I began using a Hurricane Electric tunnel on an Ubuntu system until my firewall supported IPv6. I have also been able to set it up on an Apple Airport Extreme.
At the moment I'm using a Hurricane Electric tunnel as well. Next year my ISP will supply us with IPv6 networks. I'm using an AVM Fritz!box 7390 router (not available in the US). When you give it a /48 network, it will set up an IPv6 /64 network on your standard network and another on the WiFi guest network as well.
Message 65 of 69
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-12-18
04:22 PM
2011-12-18
04:22 PM
Re: IPv6
grunnsat wrote: I see. It seems the Etch distribution is outdated, and has been replaced by the Lenny distribution. However it also seems that the Etch distribution had an IPv6 stack.
oops, I think I was getting confused with x86. Sparc ReadyNAS use sarge which is even older than etch.
If there was an easy way to get IPv6 on Sparc ReadyNAS one would think it would've been done by now.
Message 66 of 69
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-12-19
12:07 AM
2011-12-19
12:07 AM
Re: IPv6
I guess you're right. I found some documentation that although the Etch Sparc distribution contains 32 bit software, it is build for 64 bit Sparc cpus. Support for 32 bit Sparc cpus ended with previous versions like Sarge.
However even the Sarge distribution already contained an IPv6 stack so it seems. I don't know if it is usable, but Netgear could have a look at it.
Message 67 of 69
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-01-25
11:56 AM
2013-01-25
11:56 AM
Re: IPv6
2013 and still can't use ipv6 addresses in nfs export permissions...
Message 68 of 69
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-01-25
12:52 PM
2013-01-25
12:52 PM
Re: IPv6
From where I saw things going before I left NTGR, I don't see this happening with a firmware update myself. Might have to be an add-on by third-party to accomplish it. We can't even get the 'Jedi' to visit these forums anymore, they aren't listening anymore.
Message 69 of 69
- « Previous
- Next »
