× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Interesting: RAID1 two USB drives
tigerten
Luminary
I always wanted to make backups of my NAS to two USB drives, to sync the two drives has not been ideal. I discovered this:
chironFS, an very old and long discontinued filesystem. The newest version is 1.1.1 in 2008. However it still works. Here is how I got it working with Readyns with amd64 CPUs (no arms packages, unless someone can compile one).
https://code.google.com/archive/p/chironfs/downloads
Install FUSE package and the chironFS ubuntu package.
create a share "virtual" within UGI.
Add this (modify to your case) to /etc/fstab:
chironfs#/media/USB_FLASH_3=/media/USB_FLASH_1 /data/virtual fuse allow_other,log=/var/log/chironfs.log 0 0
restart ReadyNAS.
you should be able to access share "virtual" . Adding or deleting file within "virtual" will simultaneously add and delete files on the two USB drives.
Don't modify USB drive content directly.
I think that is it.
Message 1 of 1
Top Contributors
Discussion stats
  • 0 replies
  • 353 views
  • 0 kudos
  • 1 in conversation
Announcements
