Reply
LCD Display Dead - ReadyNAS Pro Business
Yeager88
Hi Folks,
Has anyone else had a problem with the OELD Display malfunctioning on the ReadyNAS Pro Business Edition (RNDP6310)? Could this be an incompatibility with the latest firmware? Does anyone know where I can find older versions of the firmware to try? Many thanks in advance for any assistance you can provide. 🙂
-Y
Message 1 of 2
vandermerwe
Master
Re: LCD Display Dead - ReadyNAS Pro Business
Is it still under warranty?
Are you running 4.2.27?
I have not heard of this problem on the forums.
What exactly is happening? Nothing on the display at all, that sounds like a hardware problem.
You could , just to be sure, power down, remove all your disks ( label them) insert a spare disk and factory default the unit. if the problem persists then it's almost certainly hardware.
4.2.26 is at the link below, but it's unlikely to make a difference, if you are planning to install that then I'd do an OS reinstall first, ( assuming you are running 4.2.27)
http://kb.netgear.com/app/answers/detai ... /related/1
Back it up. Use UPS.
Infrant Readynas NV+ | Readynas Ultra 6 Plus | Readynas 316
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 3804 views
  • 0 kudos
  • 2 in conversation
Announcements
