Yionel
Oct 11, 2013Aspirant
Maximum capacity storage per disk with readynas nv+
Hello,
I'm sorry, I am newb in NAS system. I have retrieve a Ready Nas Nv+ (back sticker RND4475)
I would know if maximum capacity storage disk was dependent of the firmware or of the NAS system ?
I am limited to 750GB per disk? (I am limited to 3 x 750GB of total storage ?)
Thank you
Thank you
- mdgm-ntgrNETGEAR Employee RetiredThe limit is 2TB disks for your NV+ (v1 - silver chassis). Please choose disks from the compatibility list.
You do need to be running somewhat recent firmware to use 2TB disks and for optimal performance it would be advisable to update the firmware then backup your data, do a factory default, then restore your data from backup.- SidCastroAspirant
so you mean 2TB disk in each bay? ie: 8TB total capacity for readynas nv+ (silver chassis)?
- YionelAspirantGreat ! thanks a lot !
- Sep 02, 2016Retired_Member
