- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
NAS DUO System Failure
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am new to supporting my NAS though I have had it for years. I just did the plug an dplay and moved movies and musing into the sytem, primarily. I have two 500GB 3.5" drives installed running Raid X.
This week the system began making un usual noises. I acessed thorugh the web interface and found that one of the disks reported a status of
dead. I shut the systsem down, took a replacement drive and inserted it hoping for the best. Now the system will not even get online I just get a flashing blue light on the front.
Researching I am prepared to take the two old drives and use a Linux Reader and recover my data. I hope?
My biggest question is how do I know if the disk is bad or the netgear Duo is bad so I don't waste money buying hardware I don't need. No support from Netgear on that topic.
Thanks to anyone on providing my best steps to take.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for all the help. I successfully added two new 1 B drives and am wokring at recovering the dta from the two 500GB drives I removed. I am also investigating the best backup system to this back up system using the USB backup funciton.
Thank you again!
Hope your year delivers you success and happiness
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: NAS DUO System Failure
Hello penyart,
Welcome to community!
The best way for you to check if the disk you removed is bad is to use diagnostic tools. After removing the suspected faulty disk, if the NAS is configured as XRAID/RAID1, you should be able to still get to your files without the replacement disk inserted and just one disk is left. Remember that one disk mirrors the other. The replacement disk you will insert should be with the same size and much better if same model/make of the still working disk.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for the awesome response. My problem is that after inserting a new disk I cannot get the system back online. i just get a blue blinking light on the front of the NAS which research tells me means it is either booting up or shutting down.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello penyart,
Is that a new disk that you inserted? No data nor partition?
Remove the replacement disk fist then backup the data while you still can. Then test the new disk too with diagnostic tools.
Is the replacement disk identical to the one left inserted?
- Mark as New
- Bookmark
- Subscribe
- Permalink
thanks for the sec0ond timely response. I thought the new disk was the same but it was 1 TB versus 5 GB. But I then tried to shut down and put the original back in to try and not lose any more data. That is when the system fialed to restart and provide access via the network.
My current plan is to shut it down, work to recover as much data form both disks to a stand alone PC using some linux reader software and then re-assess the disks and NAS device.
Does that sound resasonable
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello penyart,
What RAID level is it using?
If that is XRAID (RAID1 automatically on ReadyNAS Duo), you should be able to recover data without the failed disk leaving the one that is not reporting dead/faulty inserted.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you again!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi penyart,
We're glad that everything worked out well. I hope that you will share ideas and contribute to the NETGEAR community.
Kind regards,
BrianL
NETGEAR Community Team
