- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
NAS Neatgear network letter
- Mark as New
- Bookmark
- Subscribe
- Permalink
I do have a NAS Netgear READYNAS NV RND4000 but since i have a new desktop i can`t connect a drive letter to my NAS.
I do see the NAS in Network connections and i multi media by these way i can connect to the NAS as also by the IP-address.
What i like to do is connect a drive letter tot he NAS.
By my second NAS this is not a problem.
Can some one help me out. Thanks in advance.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: NAS Neatgear network letter
The first step is to go into "turn windows features on or off" in the PC, and make sure that the SMB 1.0 client is installed. Have you done that?
Also, what firmware are you running in the NV+?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Stephen SMB1 .0 was turn off, but still have the same problem can not connect to ip adres of find a drive letter.
i do use firmware RAIDiator 4.2.31
hope you can help me further.
thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Did you also enable SMBv1 in Windows settings? These older NAS units are, to my knowledge, only capable of SMBv1 so you must that.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Then you don't have an RND4000. Perhaps look again at the product label, or install RAIDar and tell us what model it gives you. https://kb.netgear.com/20684/ReadyNAS-Downloads#raidar
The SMB 1.0 client needs to be turned ON.
- Mark as New
- Bookmark
- Subscribe
- Permalink
i did enable SMBv1 in Windows settings.
the model is RNDX4000 says the label see also attachment
- Mark as New
- Bookmark
- Subscribe
- Permalink
@haka1311 wrote:the model is RNDX4000 says the label see also attachment
Ok. That's an NVX - quite different from the NV+.
Good.
Now try running CMD (just enter CMD from the windows search bar). That will open a black text box. Enter the following commands:
net use * /delete
net use t: \\nas-ip-address\C /user:admin nas-admin-password
using the real NAS ip address and admin password. Be careful on the typing - particularly the slash directions and the spaces.
The first command terminates any open SMB network sessions in the PC. If it prompts you to proceed, say yes.
The second command attempts to mount the NAS data volume as drive letter T. Let us know if that command works - and if it doesn't what error you get. Note the command won't work if you are still using netgear1 for the admin password.
- Mark as New
- Bookmark
- Subscribe
- Permalink
i do get error message 67,and text can`t find networkname
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
yes i can ping the adress
and used the line net use t: \\192.168.0.220\C /user:admin my password
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Great it works.
Thanks for your help
